Solved HP Mini 5103 Ethernet is automatically disabling on battery power mode
Hikeman
Power User
3:15 AM
Hello guys. I have a little issue here. I've got a HP Mini 5103 netbook and I am using Ethernet connection for internet.
The problem is that every time when I am unplugging the the charger from the laptop (meaning: laptop is working on battery power).
I suppose it is some kind of power saving option, but the fact remains that it's totally sucks, cuz then I have to keep the charger plunged all the time.
I tried to check the Advanced power settings, but there is no option to change Ethernet power settings, also I checked in the Devise Manager in Advanced menu of the Ethernet,, but again no luck to find a setting that would disable that function.
Pleas if you know anything about this problem,, help me out here :)
Windows 7 SP1 Ultimate x64Intel Core i5 M430 2.27 GHz 2.27 GHz3952 MB (DDR3-1066 DDR3 SDRAM)ATI Mobility Radeon HD 5650 (1024 MB)
SONY VAIO VPCEB1S1E
Intel Ibex Peak-M HM55, Intel Arrandale
Realtek ALC269 @ Intel Ibex Peak PCH - High Definition Audio
Generic PnP Monitor [NoDB]
1366x768
Toshiba MK-5055GSX 500 Gb
Hikeman, have you tried the power settings in control panel?
Also, you are checking the power settings while running as administrator?
device manager. for the ethernet card should have a power settings tab if your in admin mode.
Also, you might check the bios settings for power.
Rich
Windows 7 Pro x64 SP1Intel Core I716 GigsNVIDIA GeForce GTX 670M
Toshiba Laptop Qosimo X870
Intel Core I7
Toshiba Qosmio
16 Gigs
17.7" laptop
1600 x 900
256 Gig SanDisk SSD for C
256 Gig Intel SSD for D
50/25 FIOS
Vipre (all you can eat for 10 machines)
IE and FF
I have dos 6.22, wfwg 3.11, win98, 2000 and xp VHD's available for testing. MS's Virtual PC works great.
Rich
Hello.
Thank you very much I managed to locate the setting in the BIOS ! ))) Thanks a lot ! The problem solved )
SONY VAIO VPCEB1S1E
1366x768
