Huge Problem with geforce 7900 GT --- horizontal lines
ok final solution to the problem!
I flashed my card to the new settings and also made sure that the boot up clocks are the same as the clocks used when into windows.
I used Nibitor 5.2 and nvflash boot cd to permanently clock my card to 525/760 from 520/750 and uninstalled rivatuner. I did some tests to try and replicate the problem but it seems the problem is gone for good. My card is out of warranty so I didnt worry about that... I just dont like middle solutions unless I have to live with them... it seems that this time this was not the case ;)
I hope this helps more people in the future.
NOTE: I also changed the boot up clocks because I had the feeling that the problem also occurred when the driver tried to change to the windows clocks. So the card is using the same clocks all the time.
Cool Im going to have to try this out later on, thanks for going the extra step man :).
Do you have the links where I can find both of those programs? Thanks
Windows 7 64bit
Windows 7 64bit
here is another forum's procedure who have the credit for flashing the card.
.:: BenchZone ::. Get in the Zone, stay in the Zone! - nVIDIA GeForce 8 Series Detailed Overclocking Guide
(I hope Im allowed to post this - of not please delete)
NOTE: The problem does not occur at all... not even at the late boot stage exactly before getting into windows. Is seems 100% stable 2 days later.
Windows 7 UltimateAmd 3800+2GB7900GT
Asus
Windows 7 Ultimate
Amd 3800+
Asus
2GB
7900GT
Onboard
LG W2253TQ
few
Hiper 730W
Coolermaster Stacker
Passive
Replied to another ancient msg I see, well my input for archives! :o
If regular video card troublshooting has failed....
So it's probably a heat issue, I'd get a third party heatsink/fan with the good stuff for paste. Arctic Silver 5!
I did this with my old 7950GT and it lowered the temp, significantly.
This is the heatsink I put on that and I would recommend it, but read instructions carefully!
Vantec IceBerq 6 CCB-A6C Premium VGA Cooling Kit (Retail)
I'd buy some cleaner for CPU/heatsinks also to get rid of old paste, the video card makers cut corners on that and you want the good stuff. 2 bottles one for removal of old paste, one for cleaning after that, under $10 for both, the new paste, around $6 and you don't use much, enough for thin coverage, I put it on bare handed and wash with Lava afterward.
Run GPU-Z before and after and marvel in the results! :D
Windows 7 Ultimate Retail Box (64-bit install...AMD FX-8350 CPU v1.15 (or 1.0F) BIOS was requ...8G CAS-7 G-Skill DDR3 @1333 (2 fours) [mobo n...Radeon HD 7950 [3 gigs of GDDR5] MSI Twin Fro...
Self Built Custom
Windows 7 Ultimate Retail Box (64-bit installed) + Service Pack 1
AMD FX-8350 CPU v1.15 (or 1.0F) BIOS was required!
MSI 890FXA-GD70
8G CAS-7 G-Skill DDR3 @1333 (2 fours) [mobo nonOC max rec'd]
Radeon HD 7950 [3 gigs of GDDR5] MSI Twin Frozr model
Realtek High Definition Audio (onboard mobo, ALC-889 chip)
2 WS LED Monitors: One LG One Viewsonic
1920 by 1080
SSD for OS: Samsung 840 Pro
SSD for VM and utilities: Adata SX900
7200 RPM SATA HDs for the rest: Hitachi and Seagate
Corsair TX850 - 850W max, in service since August 2010.
Thermaltake Armor A90
Thermaltake Spin Q CPU Cooler, in service since August 2010
Logitech G11
Logitech M310 Wireless
100 Megabit broadband supposedly upgraded from 50 (Cable)
Bitdefender Internet Security 2014 suite
Pale Moon 64-bit main, also IceDragon, Opera, and Maxthon.
CompTIA A+ certified (220-800 series) in July 2013.
