Icons, keyboard shortcut, folder setting... Annoying bugs! How to fix?
unko
4:44 AM
Hello,
I got some annoying bugs on my Windows 7. The most annoying actually in the "apps and features" section won't remember its display settings (by date for example) and always reset itself as soon as i leave it. Second thing, which is totally new : shortcut win+L (lock session) doesn't work anymore, even after reboot, wipe caches, etc.. Not even a single idea how to fix it?
Last annoying thing is the icons gettings messed up some times after system's started and apps launched. I of course wiped all caches but it's still doing it. Of course i do a fresh install and all that is gone but i'd like to learn a bit... In fact i did a fresh install but a problem makes me avoid it :
On the old install, when i wake from sleep, wlan connects IMMEDIATLY. On the new install, it waits at least 10seconds before starting to search for the network... Hope you can help (for the display bugs mostly)!
THanks.
Win7x64
Win7x64
Windows 7 enterprise 64 bit, Windows 7 Pro 64...Core i5-2400, Athlon 64 X2 6400+ ,Core i7-3632QM4GB, 4gb g.skill ddr2, 8gbRadeon HD 4550 sgb, Radeon HD 4870, NVIDIA Ge...
Lenovo ThinkCenter, Custom Built PC, Acer Aspire V3-771G-9809
Windows 7 enterprise 64 bit, Windows 7 Pro 64 bit ,Windows 8 64bit
ASUS M4A79 Deluxe
Radeon HD 4550 sgb, Radeon HD 4870, NVIDIA Geforce GT 650m
dual samsung 22" monitors
500GB, Western Digital WD Blue WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb/s, 1TB
Antec Twelve Hundred V3 Black Steel ATX Full Tower
ASUS Silent Square Pro
Razar Death adder
20 mbps
Thanks for the fast answer but answer's not here sadly. About the win+l shortcut : As said it doesn't work BUT others (win+d, win+x, etc..) WORKS.
Win7x64
Win7x64
Found out that when i have the win+l issue, ctrl+alt+del is also not working. Even before you start thinking about it : No i have no malware/virus.. I also found out that pressing ctrl+shift+esc (task manager) then fix the issue... Until it comes back. So why is that thing coming? I've yet to find that... Could it be related to Google chrome?
Win7x64
Win7x64
@thread starter Did you try running "sfc /scannow"? Press Windows+R and enter that command without quotes. After it's done, reboot.
If it still does not work, you may run this ** REMOVED ** fix tool which I found while googling. That may solve your problem as well.
i've ran "sfc /scannow" and it says al is ok. Ok i'll try the zip but first you gotta tell me what it does (and if it auto reboot once done)!
Win7x64
Win7x64
I am very sorry unko. I myself was stunned to see what I posted there. Please don't use that, it's not meant for you. Actually I wanted to post it in some other thread but did it here by mistake, my bad.
Sorry again.
Ok thanks, anyways as said, i have a work around for that : press ctrl+esc. Now what about the other issue, for example first one "apps & feature" not remembering display settings?
Win7x64
Win7x64
Sorry, no idea, someone else might help. :(
Hope so..!
Win7x64
Win7x64
No one, really..? :(
Win7x64
Win7x64
It's like many things (settings) reset themselves often. Like i disabled auto execute and it'll be re-enabled (default setting) same for some power saving settings... Really hope to get help, can't reinstall!
Win7x64
Win7x64
bump! :(
Win7x64
Win7x64
