I'm in Hell - strange partitioning and stability problems, please help
plzhelpiminhell
1:10 AM
Hey, all. I need some help.
I just got a new hard drive for my laptop to replace an old one that went bad. Unfortunately, Windows will not install to the laptop (or work, on the one occasion I've succeeded).
Every time I've tried to install Windows 7 (32-bit or 64-bit), it tells me that it can't format any of the partitions on the hard drive and/ or that Windows could not be installed on unallocated space, always giving me error code 0x80070057.
Booting into cmd and using diskpart gives me generic "I/O error"s when I try to format anything.
Windows XP also gives me an error when trying to format either the hard drive or any particular partition.
The one occasion I did get it to install was by booting up into Ubuntu live and using gparted (which always gives me a warning telling me that the device driver believes the block size to be 2048, but Linux thinks it's 512, whatever that means) and gnome-disks to create a new partition table using the msdos option and then did a (quick) format in NTFS.
It took five hours to install, and once it did, everything (including Windows explorer) started failing randomly within two minutes of booting up the computer.
I also briefly tested a Linux installation on the hard drive and installed a bunch of software using apt-get, which all seemed to work fine (in contrast to Windows, which couldn't modify anything on the filesystem without falling apart).
I deleted Ubuntu after a couple hours of use, but I noticed no problems with it.
All BIOS dianogstic tests (memory, hard drive, etc.) pass with flying colors, other than battery, which fails miserably, because the battery is basically dead.
CD/DVD/USB all work fine, and I was ripping DVDs using an Ubuntu USB install for weeks before I got the new hard drive, with no problems.
I can't figure out for the life of me why this is happening. Does anyone have any ideas? Any help you can provide is greatly appreciated.
7 Ultimate 64-bit
7 Ultimate 64-bit
Welcome to the forum. Use diskpart to clean the drive DO NOT create paritions then try install let windows create paritions. Are you sure the old hd went bad not the disk controller gone bad?
win 8 32 bit
win 8 32 bit
Thank you.
The old HD is definitely bad. How would I test to know if the disk controller is also bad? BIOS diagnostics told me the drive was fine, and Ubuntu allows me to create and format partitions, and seems to install fine.
I tried "clean all" yesterday, and I'm pretty sure it gave me an I/O error.
I may try that again here in a minute; I currently have Ubuntu live doing a slow NTFS format over the entire hard drive to see if that will help, since a quick format allowed me to install W7 last time before failing.
7 Ultimate 64-bit
7 Ultimate 64-bit
Which hard drive precisely?
    7 X64i5 84002x8gb 3200mhz
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    pure power 11 400w cm
    Coolermaster
    cryorig m9i
    7x64g54008gb ddr4 2400
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
It's a 500GB hard drive that I just bought at Best Buy (though, in reality, it only has 465GB of space on it (is that normal? I'm aware most devices have a little overhead, but 465 still seems a little low).
I believe that Windows likes to call it disk 0, and Linux mounts it as /dev/sda.
I found a post online saying that the block size issue can be solved by using the Linux command
sudo dd if=/dev/zero of=/dev/sdd bs=2048
, but I CTRL+C'd out of it before it was finished out of frustration (had written ~190GB); it didn't seem to help anything.
7 Ultimate 64-bit
7 Ultimate 64-bit
“A patriot must always be ready to defend his country against his government,” Edward Abbey
I love this, by the way.
7 Ultimate 64-bit
7 Ultimate 64-bit
Truer words were never spoken.
We don't know the casualties yet. London Bridge. Armed police and emergency services incredibly fast response, or it would have been a lot worse.
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    Coolermaster
    cryorig m9i
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
465 is normal for a nominal 500gb drive.
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    Coolermaster
    cryorig m9i
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
The Windows explorer UI displays hard drive storage as a powers of 1024. Therefore a 500GB hard drive of 500,000,000,000 bytes will be reported by the Windows UI as though it is only 500,000,000,000 / (1024*1024*1024) bytes, or 465.66 GB
but do not worry, you really do have 500GB. To check, do
start > run > wmic logicaldisk get size,freespace,caption
it should say you have 500GB
Win7 pro x64stock i7 7700kCorsair Vengeance LPX 16GB (2x8GB) DDR4 @ 320...integrated Intel HD 630
diy
Win7 pro x64
stock i7 7700k
Gigabyte Z270N-WIFI mini-ITX
Corsair Vengeance LPX 16GB (2x8GB) DDR4 @ 3200MHz
onboard Realtek ALC1220
two vertically mounted samsung 55" 4k un55mu8000
1920x1280
256GB Samsung EVO 960 M.2 pci-e NVMe SSD
SilverStone Nightjar ST45NF 450Watt Fanless
No case. Motherboard is mounted directly onto power supply
Evercool low profile 815EP with Panaflow 12L fan at 7v
Ortek MCK-86 mini
Belkin 5-button USB
spectrum 400mbps
Oh, right, of course. That makes sense.
I just assumed they'd display the hard drive storage in the same base-10 number system used by most people and program outputs and every society on Earth, instead of using some obscure exponential system subsequently reformatted to look like said base-10 system.
But, no, of course not; that would be silly. What was I thinking?
7 Ultimate 64-bit
7 Ultimate 64-bit
