Hi there,
Recently bought an N300 wireless adapter for my PC. I have a normal router which I usually connect to the internet using an ethernet. But sometimes I go wireless.
Initially it all worked wonderfully, without the ethernet my PC was able to pick up the wifi and I could browse, however, after about 5 minutes the bar graph in the bottom right hand corner gains a yellow triangle. Then limited access announces itself and soon enough no page loads at all.
The Netgear 'genie' doesn't show any problems with the connection, the problem seems to be noticed by the windows connection icon in the bottom right hand screen. If I try to reconnect I don't get given the network options I once had.
Hope the above makes sense...any ideas?
- Computer type
- PC/Desktop
- Gladiator X8320-HD Piledriver Eight-Core
- Windows 7 Home Premium 64 bit
- AMD FX-8320 3.50GHz (4.00GHz Turbo) Socket AM3+ 8-Core Proce
- Motherboard
- GIGABYTE GA-78LMT-USB3 AMD 760G (Socket AM3+) Micro-ATX Mot
- 16GB Corsair (2x8192) 1333MHz DDR3 Dual-Channel Memory (32GB
- Graphics Card(s)
- Radeon HD 7850 1024MB GDDR5 PCI-Express
- Monitor(s) Displays
- AOC 936swa
- Hard Drives
- 2TB (7200rpm) SATA 3GB/s (SATA II) Hard Drive
seagate ST2000DMOO1-9YN164
- PSU
- 600W Corsair Builder Series 600CX 80PLUS Bronze Power Supply
