From my post. This information is needed.
What bios thing did you do?
Do you have the motherboard manual?
Let me try to be more exact.
Do this.
Starting hardware.
1. CPU
2. Motherboard
3. Ram
4. Video card
5. Power supply
ect.
Parts changed for testing and the results.
A.
B.
C.
ect.
Parts the computer has now.
A. CPU
B. Motherboard
C. Ram
D. Video card
E. Power supply
ect.
I'm trying to figure at what stage things went to hell in a hand basket.
So specific i can:
Starting Hardware:
1: Cpu: AMD A10 7700K
2: Mobo. Gigabyte GA-F2A88XN-WIFI
3: Ram: Crucial Ballistix Sport 1600Mhz CL9 8Gb kit 2x4
4: gpu: Gigabyte GTX 650 2Gb GGDR5
5: Psu: Be-Quiet Pure Power L8 630W
6: Case: Fractal Define Node Black
7: Cooler: Coolermaster Seidon 120V with noctua 120mm PWM for the radiator
( Did use another cooler at the first. But it didnt even fit at all so im not even counting it in. but becouse i want to be as specific as possible im telling you this.. )
8: 1Tb SSHD Seagate
Parts changed for testing and the results:
A: Motherboard ( Changed it to the exact same . We thought it was defective )
Result: No change, Still no signals
B: Cpu ( Same as above )
C: Cpu ( From 7700K To 6800K )
Result: Signals,
What we did: Change Fan control from 0.75Pwm per c to 1.0Pwm per c
restarted for settings to take action, System yelled it wanted an operating system.
We took out the drive. Plugged it into my computer and i Formated the disc to then be able to use the Corsair Cloning Kit to transfer everything from his old drive to his new drive. Drive wasent detected by the Corsair software.. We thought to just not care for that now and we plugged in his old WD Black 1tb drive with operating system. The computer now stopped giving signals... this is where it all whent to hell..
After it whent to hell changing list:
A: changing Harddrives from his new and his old drive and also tryed using my own 1Tb Seagate SSHD with windows 8.1,
Results: No signals
B: Changing ram sticks. 4Gb single channel on both the DDR3 1 and DDR3 2 ports on the board
results: No signals
C: Using my crucial ballistix sports 16Gb kit 2x8Gb Dual channel and Single channel on both ram ports:
Result: No signals
D: Checking all power connections over and over again
Result: No signals
E: Taking out the gpu
Result: No signals
F: Testing every Video out connector and every Usb connector possible with multiple monitors mice and keyboards
Results: No signals.
Parts the computer has now:
1: Cpu: AMD A10 6800K
8: 1Tb SSHD Seagate
Hope this is good enough
