Monitor issues; acer input not recgoginsed. plz help!!
TheDirtyBomb
10:46 AM
taree (aka middle of nowhere)
hi
i recently upgraded my parents old machine to windows 7. the model is an ACER aspire t300. now the issues arose when i found that most of the drivers for this platform are XP compatible only! this wasn't much of an issue until i started the install. the monitor cut out and displayed input not supported. the monitor is an ACER x223hq. it also is stuck on 800x600 res. I've tried every thing form installing new drivers to searching for alternatives with no success.
thnx in advance for any help:D
samsung R610
windows 7 ultimate X64 sp1
centreno duo 2.4GHz
nvidia 9600m
onboard
Samsung spin point 1tb
hi
Have you tried installing the XP drivers in compatibility mode?
Right click the installer>properties>compatibility> choose XP-SP3
Good luck
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
it didn't work:(
the monitor still displays input not supported whenever i change the resolution.
samsung R610
centreno duo 2.4GHz
nvidia 9600m
onboard
it didn't work:(
There may not be a solution. Have you contacted the mfr?
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
There are no Windows 7 drivers for it and Acer will not be making any so you are unfortunately out of luck.
Home build
Windows 7 Pro x64
AMD FX 4100 4 Core 3.6GHz AM3+
ASROCK 970 Extreme3
16GB G.Skill RipjawsX
Radeon 6850
ASUS Xonar D1
ASUS 23" LCD
SSD 120GB
WD 750GB Black series
WD 640GB Black series
700W
Antec 100
Hyper 212 Plus
50MB
