Solved My desktop icons will not open when I click on or right click on them
purplelover
9:32 PM
Michigan
I have never seen this before with all the puters I've had. I am running Windows 7, on a Dell laptop. I did install
Avast several days ago. You never realize how much you need something till you can't have it.
Windows 7 Home Premium 64bitIntel R Core (TM) i5M 450 @ 2.40GH 6GB (5.80 available
Norton 360
home built
AMD Athlon II x4 620
Gigabyte GA-MA785G-UD3H
6GB GSkill DDR2 800
AMD 4670 GPU + AMD 4200 IGP
on board Realtek ALC889A
OCZ Vertex 3 120GB,
Samsung F3 1TB (3),
Corsair 500 W
Rosewill mid tower
CM 90mm rifle
Avast, MBAM3, EMET, WinPatrol
Pale Moon, Firefox, IE
2 multi-boot PC's
Trendnet USB KVM.
David,
On Feb. 5th my hubby installed Avast antivirus software, same day he uninstalled lots of junk that crept into my computer when I downloaded something. I went back to Feb 2nd and used that for the reset. It uninstalled the avast but also one thing that I could not find to deltete. After reset I could use my icons and they loaded right up. Hoping this fixes it and he can reinstall Avast with no problems.
Thanks David for a quick fix to an irritating problem. I am a happy camper!!!!! :D
Norton 360
You're welcome and glad to hear that worked for you.
Hopefully it was the junk that caused the problem, and not Avast.
home built
6GB GSkill DDR2 800
OCZ Vertex 3 120GB,
Samsung F3 1TB (3),
Corsair 500 W
Rosewill mid tower
CM 90mm rifle
2 multi-boot PC's
Trendnet USB KVM.
