EvilOzzmess
Banned
Well, I am not ashamed to admit that I don’t know how to use a direct Ethernet connection on a Notebook PC as I’ve never tried it before.
So with that said… I’d like to know if I simply plugged the Ethernet in, if it would “autodetect” the connection or else if I’d have to set up a LAN network for it first? And after I get that going, how do I tell the NIC to stop feeding off of the wireless network, and use the physical connection instead?
The reason I want to try this is to see what the hype is all about with the CAT6 Ethernet that I just picked up. I only get between 150 and 300Mbps on the wireless right now… so it would be sweet to primarily be on Gigabit speed instead, most of the time anyway.
Thanks so much in advance, you guys rock as always!
- Acer Aspire 5738PG-6306
- 7 Ultimate x64 SP1
- Core 2 Duo T6600 @ 2.20GHz
- Motherboard
- Acer JV50 | Intel PM45 Chipset | BIOS Phoenix v1.21
- 4GB SDRAM DDR2 667
- Graphics Card(s)
- ATI Mobility Radeon 4570HD 512MB VDDR3 (2.25GB HyperMemory)
- Sound Card
- Integrated Dolby Home Theater HD Audio Support
- Monitor(s) Displays
- 15.6" LED backlight HD/WS CineCrystal w/ Multi-Touch
- Screen Resolution
- Notebook: 1366x768 | Syncmaster P2370HD: 1920x1080
- Hard Drives
- Primary internal: 320GB WD3200BEVT-22ZCT0 @ 5400 RPM | Secondary external 1: 2TB Cavalry CAXB3702T0 @7200 RPM (USB 2.0) | Secondary external 2: 500GB Calvary CAUM @7200 RPM (USB 2.0).
- PSU
- AC Adapter
- Case
- Blue Clam shell
- Cooling
- OEM Bult-in.
- Keyboard
- Microsoft Wireless 3000 (USB)
- Mouse
- Logitech V220 (USB)
- Internet Speed
- 31Mbps DL/25Mbps UL - Verizon fiOs/Netgear WNDR37AV
- Other Info
- EXTERNAL DISPLAY: 23" Samsung Syncmaster P2370HD | EXTERNAL SOUND: 300 Watt MX-KB30 JVC Stereo (AUX) | ROUTER: Netgear WNDR37AV 802.11a/b/g/n Dual-Band Gigabit | Satechi 12-Port USB 2.0 Hub | GAME PAD: SteelSeries 3GC USB 2.0 (JoyToKey Mapping) | DETAILED SYSTEM SPECIFICATIONS: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5265887&CatId=4938
