My 3rd logitech usb headset conked out today. The stupid things literally have a lifetime of about 3 months before they short out and quit working in one ear... So I started looking around at my replacement choices, needless to say that my choices are severely lacking.
But here are my problems... The front sound ports have never worked on my rosewell case, its like they incorrectly wired them at the factory or something. So I cannot get a regular 3.5mm based headset, unless I want to have to pull out my rig just so I can swap around the audio plugs in the back.
I would just get another usb headset, but none of them seem to have all to great reviews. Plus the USB ports in the front of my computer appear to be wearing out "have had this case for about 5 years now".
So here is what I need advice on... what would be the best choice of action for me to take to fix my problem?
-Should I attempt to replace the defective and worn out usb and sound ports on my front panel? Where would be the best place to get parts to accomplish this?
-Should I just buy a "multi hub" type of device that simply goes in one of the optical drive bays? What would be the best brand to get if I do this? My problem with this though, is that the front hubs never seem to look that great and are usually loaded with things I cannot use like a firewire port.
-Or should I just buy a usb hub and usb based soundcard and just route them to the front from the back of my pc? If I do this, then which ones do you recommend?
Also what brand/model of headset do you guys prefer? I really want a ballance of durability and quality.
- Custom Built
- Windows 7 Professional x64
- Intel Core 2 Duo E8400 3.00 GHz
- Motherboard
- GIGABYTE GA-EP43-UD3L LGA 775
- 6.0GB (2x 2GB & 2x 1GB)
- Graphics Card(s)
- EVGA 512-P3-N807-AR GeForce 8800GT AKIMBO 512MB
- Sound Card
- Intergrated
- Monitor(s) Displays
- HP 2009m 20"
- Screen Resolution
- 1600x900
- Hard Drives
- 1x Seagate Barracuda 7200.10 ST3250410AS 250GB SATA - Primary
1x Unknown Emachene 100GB IDE - Backup
1x Unknown Emachene 80GB IDE - Backup
- PSU
- OCZ StealthXStream OCZ500SXS 500W
- Case
- Rosewill RZS06 SLV Black
- Cooling
- Arctic Cooling Freezer 7 Pro CPU Fan
- Keyboard
- Microsoft Natural Ergonomic Keyboard 4000 v1.0
- Mouse
- Logitech Trackman Wheel Optical
- Internet Speed
- 3.0 mbps
