Need help on picking the right battery
AlexRD
Pro User
7:47 AM
Ponta Porã, MS
Hi
I bought a wireless mouse and keyboard that have fallen short in the whole "durable battery" aspect.
I don't know if its because i bought a refurbished version of them, but right now i think i need better batteries, but i don't know how to pick the best one.
I'm looking for the best AA rechargeable battery for my k800 keyboard, i don't mind spending a little for those. Can i pick a lithium one? Or will it not work ?
Thanks,
Alex
Windows 7 Professional x64
Intel Core i7 2600k - 3.4 GHz
Asus Maximus IV Z68 - Extreme
4x4 Ripjaws X79 Series 2133 MHz (9-11-10-28)
1x eVGA GTX 580 - 3GB Classified
Realtek ALC 889 HD Audio
Full HD Philips TV 32"
1x Crucial m4 SSD 512 GB
800W Coolermaster Silentpro Gold
Sentey - Renegade GS-6200
Logitech K800 Wireless
Logitech Performance MX Laser
10MB Internet Connection
I would suggest some NiMH (Nickel-Metal Hydride) rechargeable batteries, plus a charger.
Dwarf Dwf/11/2012 r09/2013
Windows 8.1 Pro RTM x64
ASRock Z77 Extreme4-M
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
Gigabyte IF233
Avast! 8.0.1497
IE 11
Eneloop cells are the best for cost effectiveness and capabilities. (They're a kind of low self discharge NiMH cells.) Most cumulative lifetime capacity potential, but not the highest capacity per charge. For higher capacity per charge but unfortunately lower (but still relatively high compared with other cells) total lifetime capacity potential there are the "XX" Eneloop cells.
The newest version of the regular Eneloops get up to 1800 cycles down to 80% usable capacity per charge, and have a very low self discharge rate, holding up to 70% of a charge after 5 years, if they're just sitting on a shelf, or similar, if I remember these numbers correctly. This means more of their charge can get used rather than wasted from self discharging over time. This also means that they can be stored charged and ready to use.
What I do is have extra sets of cells charged and ready to use so that when the cells I'm using in a device get low, I'll take them and put them on the charger, and use the charged ones that are waiting. No waiting for the cells to charge. As convenient as primary cells (actually more convenient, since you don't have to keep buying more of them), and a lot more cost effective in the long run. (1 Eneloop AA cell approximately equals 1000 or more name brand alkaline AA cells in total cumulative lifetime capacity potential.)
Not sure if these 1800 cycle ones are common in the US yet (they're made in Japan). It might still be the 1500 cycle ones over here that are more common. Either way, they're still great batteries.
They make both AAs and AAAs.
A great charger is the MH-C9000. And of course, to get the most out of your rechargeable cells, you should learn how to properly take care of them and how to optimally use your specific charger for them. Rechargeable batteries are kind of like an investment. Candle Power Forums is a great place to look for more info. Maybe do a Google search for Candle Power Forums Eneloop MH-C9000 or similar for more into.
Also, I believe that the Duracell pre charged/stay charged NiMH cells with the white insulation on the top of the cells around the positive contact are rebranded Eneloops. They're often referred to on-line as "Duraloops." I haven't tried them personally though. I just order my Eneloops on-line from either Amazon or Thomas Distributing. Might be a good idea to stay away from ebay though, since there are reports of some counterfeits out there.
"Lithium" AA and AAA primaries? Yes, most likely. "Lithium" rechargeables (such as LiFePO4 or Li-ion)? No, they're the wrong voltage.
As mentioned, NiMH cells are your best bet.
If you have any more specific questions, including how to care for your rechargeable cells, I can likely answer them here for you as well.
Regards.
Windows 7 Professional SP1 64bit, Manjaro Xfce, Debian 10 64bit Xfce
Intel i7-3930K @ 4.2GHz
ASUS P9X79 WS
Corsair Dominator 64GB Quad Channel DDR3 @ 1600MHz
EVGA GeForce GTX Titan Black Superclocked (×2, SLI)
Sony Bravia 46"
1920×1080 (Full Screen), 1366×768 (Windows)
Samsung 860 PRO 4TB SSD, Samsung 850 EVO 1TB SSD, Western Digital WD Gold 16TB 7200 RPM 512MB Cache HDD
Corsair AX1200 (1200W, 100.4A @ 12V)
Corsair Obsidian 750D
Corsair H110, 5 NOCTUA NF-A14 industrialPPC-3000 PWM Fans
Logitech K360
Logitech M220
Firefox Developer Edition, Pale Moon, Tor
