Need help solving dump and crash problem
First off, it was my RAM that was causing the dumps. That issue was solved by going into the bios and manually setting the RAM voltage to its rated 1.65V.
Second, you'll want to let the win7 experts here know what you are running when your system locks up. Is it during particular applications. In my case, after setting the RAM voltage, it was only when running VLC that my system locked up. I did a clean reinstall of win7 and have avoided using VLC. Since then I haven't encountered a dump.
Thanks for reporting!
What process is running usually shows up in the dumps, that's why we don't ask all the time.
Windows 7 Professional x64
Intel i7 2600K OC'd @ 4620 MHz
Asus P8Z68-V Pro
16GB GSkill Sniper 2133 Mhz (4x4GB)
EVGA GeForce GTX 480 SuperClocked+
2x Acer S273HLbmii 27"
2 x 1920x1080
64GB Crucial M4 SSD
Storage: Hitachi 1TB 5400RPM, Samsung 1.5TB 5400RPM
Corsair HW Series 750w (modular)
Cooler Master HAF 932 Advanced Blue Edition
CM Hyper 212+ CPU cooler, 3x 230mm + 1x 140mm case fans
Logitech MK320 (wireless)
30 Mb/s : 2 Mb/s
