Need help solving loud fan issue
stnewlon413
12:43 AM
So this problem started a few months ago when I tried playing a PC game on my computer. All of a sudden, one of the fans inside the PC starting going CRAZY. Like, REALLY loud. I turned off the game, and everything went back to normal. no noise. I tried it again when Elder Scrolls Online came out, and the fan is going insane again. I turn the game off and I get no noise.
I'm fairly certain it's my graphics card that is making the noise, but I also wanted to be safe and reapply thermal paste to my cpu fan just to make sure. Is there any way to quiet down the graphics card so I can play my games in peace and quiet? Or is this something I'm going to have to live with?
Windows 7 Home 643.4 GHz8gbNvidia GTX 660 Ti
Asus Essentio CM6830
Windows 7 Home 64
3.4 GHz
8gb
Nvidia GTX 660 Ti
2 TB
Do you have fans blowing into and out of your case? More air circulation means that the GPU fan has to work less hard to keep the GPU cooler.
Mellon Labs (custom build)
AMD FX 8350 Vishera @ 4200
ASUS M5A97 R2.0
Acer 24", Acer 22"
3840 x 1080
1 x WD 1TB SATA Blue
1 x WD 1TB SATA Green
Corsair TX-750
CoolerMaster HAF 912+
Logitech G710+
Logitech G500s
Corsair VOID USB headphones.
Don't be fairly certain. Be absolutely certain. Do that however you can, possibly by physically stopping various fans for one second by hand to see if the noise disappears. Get your head inside the case.
Have you checked CPU temps with a temp monitoring application? Unless CPU temps are excessive, I'd seriously doubt any re-application of thermal paste to the CPU will have any effect.
If the noise from your graphics card fan is in fact the cause of the noise, that fan may be failing outright and require replacement--particularly if that game didn't cause fan noise previously.
Dell S2340M 23 inch IPS
1600 x 900
Antec Solo II
Microsoft 200 6JH-00001 USB
Pale Moon
It could well be the PSU as it's being put under load. As mentioned above, make sure you know exactly which can it is first and foremost.
W7 Pro x64 SP1 | W10 Pro IP x64 | W8.1 Pro x6...i7-4790k @ 4GHz (4.4GHz Boost)16GB DDR3 Kingston HyperX Fury @ 1600MHz CL 9...EVGA GTX 980 Classified
Realtek Onboard
Samsung S27D390
240GB Intel 520 Series SSD |
Samsung 850 EVO 120GB SSD |
2TB WD Caviar Black |
2TB WD Caviar Green
Corsair HX850-80 Gold Modular
Cooler Master Silencio 650
Microsoft Sidewinder X4
Gigabyte M6900 optical
152mb
F-Secure
Firefox 38.0
