The error indicated fileinfo.sys
I would suggest to try running Startup Repair from the installation DVD. Startup Repair will check the filesystem on the disk (FILEINFO.SYS errors). If it doesn't complete successfully, then you'll have to run chkdsk /r from the Command Prompt.
Bugcheck
~Tuan
Bugcheck
Microsoft (R) Windows Debugger Version 6.12.0002.633 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\TUANTR~1\AppData\Local\Temp\Rar$DI02.872\062610-18642-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*e:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7600 MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7600.16539.x86fre.win7_gdr.100226-1909
Machine Name:
Kernel base = 0x81811000 PsLoadedModuleList = 0x81950570
Debug session time: Sat Jun 26 07:21:15.294 2010 (UTC + 7:00)
System Uptime: 0 days 0:44:14.934
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000008E, {c0000005, 86bab885, a6807810, 0}
Probably caused by : fileinfo.sys ( fileinfo!FIStreamGet+36 )
Followup: MachineOwner
~Tuan
Microsoft Window 7 Professional 32 bitIntel Centrino2 vPro2GB DDR3ATI Radeon 3400
- Lenovo T400 2767 2JU
- Microsoft Window 7 Professional 32 bit
- Intel Centrino2 vPro
- 2GB DDR3
- Graphics Card(s)
- ATI Radeon 3400
- Sound Card
- Conexant 20561 SmartAudio HD
- Monitor(s) Displays
- Thinkpad Display
- Screen Resolution
- 1280x800x49 hertz
- Case
- Magnisium, Fe, etc..
- Keyboard
- embeded
- Mouse
- Logitech
- Internet Speed
- 54Kb/s
