Need help with Front Panel HD Audio
McSeven
1:01 PM
I have had this problem for months and I have never been able to solve it.
Bios is set for HD Audio. When I connect the front panel hd audio plug from my Lian-Li A77 case into the Asus Rampage II Extreme Supreme FX mini sound card the system will boot up normally. Then when I plug in the microphone all is ok and the mic is perfect. System sound is normal and just awesome.
BUT when I plug in the headset the system crashes and the computer turns off. I have tried different headsets too. :confused:
All software is up to date and kosher as far as I can tell. This is a really strange problem.
Any help would be appreciated.
Sorry.
I ask you where to buy, I will correspond to a window security.
Thank-you
LIAN-LI
W7 Prof 64 biti7-3770kG.Skill Sniper 1866 16 GBEvga GTX 770
HomieJunker
W7 Prof 64 bit
i7-3770k
Sabertooth Z77
Evga GTX 770
Sound Blaster Z
Asus VG278HE
4 Seagate Barracudas 250 GB
2 Intel® X25-M 160GB
Corsair H1000X
Lian-Li A77B
Phantek 120 dual fans
Corsair K70 RGB
Logitech G502
FiOS Quantum
Avira
Does this problem occur if you plug the headphones into the line out jack on the back of the Supreme FX card? If not then you may have a short in the line provided by Lian Li to the I/O panel jack. I'd remove the I/O panel to see if a proper connection is being made or if there is a short occuring up at the connector.
Windows 10 Pro 64 bitCore i7 6700K Skylake 4.0GHzCorsair Vengeance LPX DDR4 32GB 3000MHzAsus Radeon RX480 Strix 8GB
Wordsworth 5000
Asus Z170 Pro
Asus Xonar DSX
HP 2709m
Intel 600p M.2 PCIe NVMe SSD 512GB; Intel 335 SSD 240GB ;Western Digital Caviar Black 1TB
Thermaltake Toughpower Grand Platinum 850W
Lian Li PC-B70
CPU-Noctua NH D15, GPU-Stock, Case-Noctua 2x140, 2x120
Microsoft Natural Ergo 4000
Microsoft Wireless Optical 1000
Cable
HP bd 340,
HP bd 240,
Klipsch Promedia 5.1 THX
When microphone and headphone are plugged into the back of the Surpreme FX card all is aok. This Lian-Li front panel strap is new! The HD Audio plug seems to be pinned correctly according to the color coding. I just can't verify the Supreme FX card socket color coding.
HomieJunker
W7 Prof 64 bit
i7-3770k
Sabertooth Z77
Evga GTX 770
Sound Blaster Z
Asus VG278HE
Corsair H1000X
Lian-Li A77B
Corsair K70 RGB
Logitech G502
FiOS Quantum
Avira
Dwarf Dwf/11/2012 r09/2013
Windows 8.1 Pro RTM x64
ASRock Z77 Extreme4-M
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
Gigabyte IF233
Avast! 8.0.1497
IE 11
I have read of brand new Coolmaster cases with front I/O panel cables shorting which is why I mentioned it. When I recently received my Lian Li case I took out the I/O panel just to check it before building with the case. That everything works when plugged into the rear of the FX card points to the I/O panel then, or at least the plugging of it into the FX card as you've been investigating.
The thread below may be of help, especially the posts by Paul Komski.
Connecting the front panel speaker connector - The PC Guide Discussion Forums
Wordsworth 5000
Asus Z170 Pro
Asus Xonar DSX
HP 2709m
Lian Li PC-B70
Cable
HP bd 340,
HP bd 240,
As of now I order a couple of 10 pin connectors. I will try and rewire this puppy.
I searched the Internet until my eyes bled. I must be the only person with this problem. lol
HomieJunker
W7 Prof 64 bit
i7-3770k
Sabertooth Z77
Evga GTX 770
Sound Blaster Z
Asus VG278HE
Corsair H1000X
Lian-Li A77B
Corsair K70 RGB
Logitech G502
FiOS Quantum
Avira
Be very careful. I know you have the pin assignments for the case cable provided by Lian Li, as do I. But I cannot find any official information on the FX card pin assignment although it should be standard audio pin assignments. but is it HD or AC97? The Lian Li cable has a connector for both. If you are plugging the HD connector into the FX card and it is HD audio, then why does it not work for the headphones provided the Pin 1 on the FX card is lined up with Pin 1 on the case cable?
In another thread the poster gives a pinout that does not match the Lian Li cable.
Again, be careful. If the headphones work when plugged into the back of the Supreme FX card it may be best to use it that way for now until you have definitive information.
Wordsworth 5000
Asus Z170 Pro
Asus Xonar DSX
HP 2709m
Lian Li PC-B70
Cable
HP bd 340,
HP bd 240,
What case and motherboard do you have?
I am with ya on the two different plugs. I tested both and motherboard bios was set correctly, but neither will work for headphone. Weird!
I have not been able to find official information on the FX card pin assignment as well.
I wonder if just the pins for the heaphone are the problem. Pins 5/6 and 9/10.
Because the mic will work with either plug! :shock:
Woops, should mention that the plug only fits one way. There are only 9 pin holes.
I found this pinout configuration at ASUS forum, but I don't trust it -
Looking for info on SupremeFX II audio card
Pinouts for the Supreme fx II 10pin HD connector on the back of the module.
1 2 3 4 5
0 0 0 0 0
0 0 0 0 the zeros are the pins the numbers are what each pin is.
6 7 8 9 10
1. Line out Left
2. No Connection
3. Line out Right
4. Micbiyes (not used in my case)
5. Mic In
Bottom Row
6. Return Left
7. BLANK NO PIN
8. Return Right
9. +5VA pos
10. -Ground
HomieJunker
W7 Prof 64 bit
i7-3770k
Sabertooth Z77
Evga GTX 770
Sound Blaster Z
Asus VG278HE
Corsair H1000X
Lian-Li A77B
Corsair K70 RGB
Logitech G502
FiOS Quantum
Avira
The Asus P6T and Lian Li PC-B70 as in my specs below.
I've seen the pinout you found at the Asus board and others as well but I would not do a re-wire by them. The idea that the headphone connector or wire is somewhere damaged is a possibility, but if you don't see any damage like a cut in the wire, something smashed, or anything melted, then I'd doubt that.
The email you received from Lian Li is something I thought of at the first, that being that Windows is shutting down because of a conflict with the audio card. But why only while using the I/O panel headphone connector, and not when using the port on the back of the card? It is a strange problem and I would keep investigating but suggest meanwhile using the port on the back of the card.
I didn't connect everything in the Lian Li I/O panel because I ran out of connectors for example for the esata wire; where headphones are concerned I have a connector on the Klipsch control module that came with the speaker system. These wires I just cable tied up and stuck away in the back side of the case.
I'd send an email to Asus requesting a schematic of the card and see if they respond.
Wordsworth 5000
Asus Z170 Pro
Asus Xonar DSX
HP 2709m
Lian Li PC-B70
Cable
HP bd 340,
HP bd 240,
Thanks everyone! I'll try Wordsworth's suggestion and try to contact Asus.
Asus support = useless !!
HomieJunker
W7 Prof 64 bit
i7-3770k
Sabertooth Z77
Evga GTX 770
Sound Blaster Z
Asus VG278HE
Corsair H1000X
Lian-Li A77B
Corsair K70 RGB
Logitech G502
FiOS Quantum
Avira
I've had a search for information on the front panel audio header on this card and have come up with a complete blank. I can only surmise that it is a proprietary configuration that will only work with a specific front panel, which you might need to order from the card manufacturer.
I wish you the best of luck.
Gigabyte IF233
Avast! 8.0.1497
IE 11
