Need urgent help setting up laptop as wifi hotspot using ICS
rede96
4:59 AM
Hi, I am on holiday at the moment and trying to set my lap top as a wifi hotspot.
I have two identical Acer Aspire one Laptops both running windows 7. I can only connect to the internet in the hotel room using one wired connection. So I wanted to set up one Laptop up so as a wifi hotspot to connect the other to it wirelessly and share the internet connection.
I can create the addhoc connection and turn on ICS no problem. I can connect the client laptop to the server but no matter what I do I can not get internet connection sharing to work!
I have even tried MaryFi and Connectivity software but that does not work either.
Can anyone help me out please?
Windows 7 Home PremiumAMD C-604GB
Acer
AMD C-60
4GB
You do realize that an Ad Hoc network is sharing a wireless connection to another wireless client?
You are trying to use ICS to create an Ad Hoc network. This isn't a supported configuration although I have seen a few people get this to work but unfortunately it's not repeatable, it's also not reliable even if they do get it to work. It's basically not a supported configuration so it's very unlikely you can get this to work reliably if at all, but if you do find a way then please report the procedure here. :)
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
GSkill Phoenix Pro 120GB SSD
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
Hi, and thanks for the reply.
I have used this setup before and had it working, although it was a while ago. I think I used MaryFi, but I have tried this again and it didn't work.
But in theory it should work as the set up I have is Laptop A is connected to the internet through the ethernet card via cable, not wireless. So once I have made the add hoc connection from Laptop B to Laptop A via wireless, Laptop B should connect to the internet via Laptop A.
But for some reason it wont :confused:
Acer
AMD C-60
4GB
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
Connectify - Turn your PC into a Wi-Fi Hotspot and Get Faster Internet this has a Pro version that may be able to do what you want but it costs money, still it's made to share a wireless connection not a wired one.
This one shows how to set up a hosted wireless network using the command prompt.
http://winsupersite.com/article/faqt...ion-wirelessly
Or you can install a virtual router.
Virtual Router - Wifi Hot Spot for Windows 7 / 2008 R2 - Home
Thanks for that. I have not tried the command prompt yet, but the other 2 do not work. I tried the free version of Connectify, but no good.
I think I may need to give up on this:confused:
Acer
AMD C-60
4GB
