No sound from HDMI device Nvidia and Realtek HD Audio
do you have speakers connected to the back of the computer?
Windows 7 Ultimate x64 RTMAMD Athlon II X2 240 @ 3.2Ghz6GB Mushkin DDR3 PC-1333ATI Radeon HD 4200 IGP Hybrid CrossFireX w\ S...
Home Built
Gigabyte GA-MA785GMT-UD2H
ATI Radeon HD 4200 IGP Hybrid CrossFireX w\ Sapphire HD3450
Onboard Realtek HD audio controller
D-SUB: LG W2343T-PF 23" LCD HDMI: LG 32LH20 32" LCD
1920*1080
WD Caviar Green 1TB SATA3
Cooler Master Elite Power 400W
Cooler Master Elite 360
AMD Stock :)
Crappy wirelss logitech
crappy wireless logitech
792k
OMG!!...I got this working now!! Realtek digital output without the passthrough enabled and with the Nvidia beta driver installed I mentioned earlier!
Many Thanks everyone for helping
Windows 7 64BitIntel Core 2 Duo3GBNvidia GeForce 7650 GS
Medion MS 7318
Windows 7 64Bit
Intel Core 2 Duo
MS 7318
3GB
OnBoard Realtek
Acer AL1916W
Medion MS 7318
Windows 7 64Bit
Intel Core 2 Duo
MS 7318
3GB
OnBoard Realtek
Acer AL1916W
It would be interesting to see if this resolves the issue for other people mentioning the same issue with Nvidia and Realtek sound issues over HDMI
Medion MS 7318
Windows 7 64Bit
Intel Core 2 Duo
MS 7318
3GB
OnBoard Realtek
Acer AL1916W
Glad to hear its now working... I have no idea how, but enjoy :)
Home Built
1920*1080
AMD Stock :)
792k
Actually...Just discovered the only problem is front jack detection does not work and so I have to manually select speaker to hear sound through the headphones...But that is not a big issue for me ;o)
Medion MS 7318
Windows 7 64Bit
Intel Core 2 Duo
MS 7318
3GB
OnBoard Realtek
Acer AL1916W
Neither do I lol! thanks for the help though...
Definately is a driver issue as searching google for "realtek HDMI no sound Nvidia" pulled up alot of threads with others having the same issue...and experienced it since updating nvidia drivers on vista...However reverting to older drivers did not help with windows 7???
Medion MS 7318
Windows 7 64Bit
Intel Core 2 Duo
MS 7318
3GB
OnBoard Realtek
Acer AL1916W
That makes two of us, but as you said it is working now and that is all that matters.
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
same Problem as amzo
Hi Amzo, Hi all
I have the same computer as you have md8818... installed win7... and now audio over hdmi does not work anymore :(
... so i tried to install the same nvidea drive as you have installed... but still no audio over hdmi :(
... what have you ment with "passthrough enabled" ... where can i do that?
(realtek driver v2.36, nvidia 8.17.11.9539, )
do you have any suggestions for me?
thx
w7 ultimate2gb
Mediaon MD8818
w7 ultimate
2gb
It would be hard for us to help resolve this issue as we have no idea how Amzo got it working... the fact that you installed the same driver as him and it isn't working brings us back to square one... but we can try
Home Built
1920*1080
AMD Stock :)
792k
Hi Patrick,
Try uninstalling both drivers and reboot in safe mode and remove drivers (for realtek and Nvidia) using a program called driver cleaner pro (look for it on the net)after that, reboot and install the video driver I had used (as mentioned on previous page...link provided) then reboot and then install realtek driver...not sure which release I used but is version 6.0.1.5953, below are a few screenshots including my current settings..the passthrough option is in 3rd screenshot (try it with and without the tick)
Medion MS 7318
Windows 7 64Bit
Intel Core 2 Duo
MS 7318
3GB
OnBoard Realtek
Acer AL1916W
I installed windows 7 on my acer aspire 6920 hdmi was working fine till i changed my os now no sound.nvidia geforce 9500m g/c tryed to recover my orig vista disk but no good i would gladly go back if i could...can anyone help please?
windows 7
acer aspire 6920
windows 7
Jackbrack81, Need more info....Are u on 32 or 64bit OS?...Have u tried the nvidia driver I mentioned in this thread??...As much info as possible plz...
Medion MS 7318
Windows 7 64Bit
Intel Core 2 Duo
MS 7318
3GB
OnBoard Realtek
Acer AL1916W
Superb....
Medion MS 7318
Windows 7 64Bit
Intel Core 2 Duo
MS 7318
3GB
OnBoard Realtek
Acer AL1916W
Hi Patrick,
Hi Amzo,
Thanks for your detailed advice... I tried it the way you suggested... unfortunately with no success :(
The only thing happended was, that my HDTV is now making a Tick-Sound in a fast interval even when music is not playing... it stops when i aktivate "Mute" on my digital out device !!??
But with the new Nvidia Driver the HDTV properties dialog from the NVIDIA control panel alows the option to have HDMI with or without audio.
But it still doesnt work anyway :(
anyway, thx for your help.
w7 ultimate2gb
Mediaon MD8818
w7 ultimate
2gb
Hi,i had the similar problem with HDMI too...all you need to do is to update your windows 7.
in the list of updates you gonna see you sound and HDMI drivers.
Windows 7,Ubuntu,Fedora,Windows XP
unfortunately that doesnt work for me :( ... I dont get any updates for HDMI or Sound via Windows Update. Win7 Installation includes drivers for my Nvidia 7650GS ... which are installed automatically if I deinstall the new downloaded NVIDIA drivers.
w7 ultimate2gb
Mediaon MD8818
w7 ultimate
2gb
not sure then mate...my 7650GS definately started working after I installed that driver
Medion MS 7318
Windows 7 64Bit
Intel Core 2 Duo
MS 7318
3GB
OnBoard Realtek
Acer AL1916W
MD8818 Unknown Device - Suspect USB Network Wireless
Hey Amzo
I too have MD8818 but have come across a different issue and would like to know if you have it too. I have Windows 7 Ultimate 32bit installed not 64bit.
My network wireless for some reason no longer works.
I have found I have an Unknown Device and suspect it may be the wireless usb network.
Unknown Device USB\VID_0000&PID_0000\6&34DBCBC0&0&2 43
The rest is as follows
VIA Rev 5 or later USB Universal Host Controller PCI\VEN_1106&DEV_3038&SUBSYS_73181462&REV_91\3&2411E6FE&1&80
VIA Rev 5 or later USB Universal Host Controller PCI\VEN_1106&DEV_3038&SUBSYS_73181462&REV_91\3&2411E6FE&1&81
VIA Rev 5 or later USB Universal Host Controller PCI\VEN_1106&DEV_3038&SUBSYS_73181462&REV_91\3&2411E6FE&1&82
VIA Rev 5 or later USB Universal Host Controller PCI\VEN_1106&DEV_3038&SUBSYS_73181462&REV_91\3&2411E6FE&1&83
VIA USB Enhanced Host Controller PCI\VEN_1106&DEV_3104&SUBSYS_73181462&REV_90\3&2411E6FE&1&84
How does it compare with yours?
Windows 7 UltimateIntel Core 2 Duo 6300 1.86Ghz2 GbNVIDIA GeForce 7650 GS
Medion MD8818
Windows 7 Ultimate
MS-7318
2 Gb
Creatix SAA7134
Lenovo L192
Seagate ST3320820AS (320 GB, 7200 RPM, SATA-II)
