Solved Non-PWM Fan on a PWM Fan Header
Lady Fitzgerald
Senioritis Member
2:46 PM
AZ, SSA (Squabbling States of America)
Is it possible to run a 12v fan (3 pin non-PWM) on a MOBO PWM fan header (4 pin)? If so, will it just run at full speed only or would I be able to control the speed somewhat?
Win 7 Ultimate 64 bit
Intel i7-3930K
ASUS P9X79 WS
Asus Xonar Essence STX
1920 x 1080, ?
Samsung 4TB 850 EVO SSDs (4)
Corsair HX750w
Logitech G510s
Logitech M525 (two in use)
=< 32Mbps down, 8Mbps up
IE11
In my experience, it should run on some or other of the 4 pins--at full speed. Fans always take some fiddling and experimentation.
Dell S2340M 23 inch IPS
1600 x 900
Antec Solo II
Microsoft 200 6JH-00001 USB
Pale Moon
No...I've got Two of my 3pins Pc case 12v fans plugged in the motherboard 4pins PWM and they still available in the monitoring speed software. I can easily set parameters speed on them.
Asus P8Z77-V LE PLUS
Asus Dual-RX480-O4G
Asus IPS 23"
Internal:
500Go Sata 6Gb/s (x2)
500Go Sata 3Gb/s (x2)
SSD 60Go Sata 6Gb/s
Thermaltake Chaser A71
Custom Water Cooling Loop
Cooler Master QuickFire XTi
Razer Imperator 2012 (4G)
IE 11.0.xxx Rtm
"Curiouser and curiouser," said Jeannie (apologies to Charles Lutwidge Dodgson), especially since my MOBO uses the same software (AI Suite II). This is good to know. Thanks!
Intel i7-3930K
ASUS P9X79 WS
1920 x 1080, ?
Corsair HX750w
Logitech G510s
IE11
You Asus users might find this thread interesting:
ASUS Z87-Deluxe fake 4-pin headers & other fan control info
Humm...my mobo have 4 headers with 4pins. I can plug two of 4 pins PWM fans (CPU_Fan & Cha_Fan) and still have the speed control in Bios (set to manual setting) & set my testing parameters in Ai Suite II software.
The two others 3 pins PC Case are also set "manual" in Bios according my demand to reflect them in AI Suite II software.
Since I can control the low/mid/high RPM percentage according to the CPU Temp and test the fans speed with Fan Xpert+, i don't see any issues in that right now.
Thanks for the link, might dig that a bit!
On screenshot it shows % w/Temp regulation for a 3 pins Fan plug on 4 pins header.
Asus Dual-RX480-O4G
Asus IPS 23"
Internal:
SSD 60Go Sata 6Gb/s
IE 11.0.xxx Rtm
I have a P9X79 WS (as in Work Station) MOBO. I took a look at my manual (yeah, I actually keep it handy and use it) and all four of the chassis fan headers show the following connections:
CHA FAN PWM
CHA FAN IN
CHA FAN PWR
GND
Nothing is mentioned about any voltage, let alone +5v. There are no little switches by the headers either. Methinks my MOBO actually does support true PWM (after what I paid for it, it bloody well better!).
Intel i7-3930K
ASUS P9X79 WS
1920 x 1080, ?
Corsair HX750w
Logitech G510s
IE11
CHA FAN PWM
CHA FAN IN
CHA FAN PWR
GND
Screenshot shows mine either...:)
Asus Dual-RX480-O4G
Asus IPS 23"
Internal:
SSD 60Go Sata 6Gb/s
IE 11.0.xxx Rtm
FWIW, my two 3-pin case fans are attached to 4-pin headers on my Asus Gryphon Z87 which has the "fake" PWM chassis fan headers, and the BIOS controls the speed, while AI Suite III provides finer control inside Windows. I've set them to idle around 480 RPM, while the CPU fan (true PWM) idles at 200 RPM. They all ramp up with CPU temp. Works great. Per that thread I linked to, PWM fans attached to the fake headers are still controllable to some extent, and it's subtle to determine from their behavior if you're getting "real" PWM.
To the OP, YMMV with other motherboards and software.
Might some 3pins fans got RPM Signal and very basic ones don't. But i do think when using 4pins PWM on those described headers its still be kind of PWM as schema shows it. Yes, Q_Fan for CHA_FAN in bios have slight different setting than the CPU_Fan.
Asus Dual-RX480-O4G
Asus IPS 23"
Internal:
SSD 60Go Sata 6Gb/s
IE 11.0.xxx Rtm
