Not sure how to describe this..HELP! Display Problem.
noyou
8:15 AM
I'm not sure how to describe this. Just 'checkered tile'-like appearing. I'm in Windows 7 7100RC, was playing game [Savage2, fullscreen] and it just SUDDENLY happened. All of a sudden. I've tried system restore and it didn't work. I would give my system information [graphics card etc] but I can't because I can't read/see it due to this problem.
So anyways....please refer to the images and see if you know anything about it..
Thanks.
the pics show the checkered tile thing which covers part of the screen, it changes location randomly when i click around or drag around. Ingame, it covers the whole screen. it affects the taskbar too [probably because of transparency]
one of the pics show how text disappear when i hover mouse over it, and in some places makes text unreadable, or doesnt exist at all. somehow doesnt affect the internet.
Thanks, any help is appreciated.
Hi, go and get the latest drivers for you Video card and your Monitor and see if it fixes it.
Also check in Windows Update to see if you have any thing to install.
Self Build 64bit
Vista Ult64, Win7600
4096 MB DDR3-SDRAM
Realtek on board
My Book 1 TB external..
Cooler Master 1000w
Cooler Master Cosmos 1000.
Fans and fresh air,
Wireless
Wireless
Never fast enough
I use a Magnum.
Also, if you go to
Control Panel -> System & Security -> Troubleshoot common computer problems (under Action Center) -> Troubleshoot. From here you can select 'Appearence & Personalization' and run both of the troubleshooters shown (Aero/Display Quality) and see if Windows displays any results
Compaq Desktop
AMD Sempron Dual Core
3GB
1024x768
150GB Sata
Also.. Try reseating your Video Card..
DELL VOSTRO 3650
Windows 8.1 PRO
3rd Generation Intel Core i7‐3612QM CPU @ 2.10GHZ
8GB DDR3
NVIDIA GeForce GT 525M (128 bit), 1GB Grpahics
1920X1080
750GB 5400RPM
+1
I've also seen a lot of this behaviour in an overheating GFX card, is the card being overclocked?
Compaq Desktop
3GB
1024x768
150GB Sata
From my observation it looks like he does not have any video drivers installed.
I know with ATI, when you right click on the desktop , you have a CCC option.
Not sure about Nvidia but I know you see something too..
DELL VOSTRO 3650
Windows 8.1 PRO
8GB DDR3
1920X1080
750GB 5400RPM
I didn't mean physically walk to where you get the drivers from.:D
Self Build 64bit
4096 MB DDR3-SDRAM
Realtek on board
Cooler Master 1000w
Fans and fresh air,
Wireless
Wireless
Never fast enough
I use a Magnum.
First of all, thanks for all the support!
I've tried troubleshooting aero/display, no luck.
I'm thinking it's possible it's overclocked, but I'm not sure how to reseat or reset my video card [both reseat and reset seems to make sense >.<]
System information says I'm using 'NVIDIA GeForce 9800 GT', and how do I know if I have a video driver installed or not?
I'm currently running Windows Update, there were a few 'optional' things but I think might be related.
Also, I've been experimenting with [rightclickdesktop>screen resolution>advanced settings>list all modes] And it seems that either 32-bit, or True colours gives the worst result. 16-bit and High colour seems to be alright, just without the Aero-ness, but once I start up Savage 2 [game] there's no difference as before. Checkered tiles fill the screen and I can barely make out what is where in the game [but words cannot be read].
Thanks! I'll let yous know what happens after Windows Update, whether it fixes.
Ok can you tell us what the motherboard is, using the same "System Information" program.
Click System Summary.
Self Build 64bit
4096 MB DDR3-SDRAM
Realtek on board
Cooler Master 1000w
Fans and fresh air,
Wireless
Wireless
Never fast enough
I use a Magnum.
Windows Update didn't fix the problem... ):
Can someone advise me where I can download drivers?
And how to reset my Video Card?
Also, in response to TGSoldier, I right clicked on my desktop and there was a NVIDIA Control Panel, please refer to the image, and advise me of what to look at?
Self Build 64bit
4096 MB DDR3-SDRAM
Realtek on board
Cooler Master 1000w
Fans and fresh air,
Wireless
Wireless
Never fast enough
I use a Magnum.
http://www.gigabyte.com.tw/Support/Motherboard/Driver_List.aspx?Keyword=ep31
That's all there is, and they can't be downloaded either [missing or something]
I tried downloading the newest driver for my video card, didn't fix problem
I tried disabling, restart, and re-enabling my video card via Device Manager [safe mode], didn't fix problem
I tried Uninstalling and reinstalling my video card via Device Manager [safe mode as well] and it didn't fix the problem either.
Does that count as resetting my video card?
Any more advice?
Thanks.
reSEAT yor card. Take it out, put it back in, making sure that it sits flush and proper. Examine fan (if it has one) for spin, dirt or damage.
Self Build 64bit
4096 MB DDR3-SDRAM
Realtek on board
Cooler Master 1000w
Fans and fresh air,
Wireless
Wireless
Never fast enough
I use a Magnum.
Download and install the latest driver for your Video card, and install it using, Compatibility Mode.
http://www.sevenforums.com/tutorials/316-compatibility-mode.html?ltr=C
It's already got the latest driver installed:confused:
I couldn't take the video card out entirely, there were no screws, and I pressed down the latch, but couldn't yank the thing out >.< it came out a little, and I pushed it back in and heard a click.
That didn't help, and I'm scared to break anything... And the fan was fine :confused:
Download and save the latest video driver for your machine to somewhere you can find it easily,
I suggest the Desktop.
Ok Just go into the Device Manager and click on your Display adapter, then right
Click on your video card, then click Update Driver Software, choose
Browse my computer for driver software, and then install the driver that is
On your Desktop.
Self Build 64bit
4096 MB DDR3-SDRAM
Realtek on board
Cooler Master 1000w
Fans and fresh air,
Wireless
Wireless
Never fast enough
I use a Magnum.
Sorry for double post
But does anyone have any more pointers? Or should I just take it to someone to have a look at?
Has anyone seen this type of situation before?
Or know where else I can get help from?
Thanks.
Will you do as I ask in the post above you and you might get somewhere.
Do you think I am sitting here for the good of my health.
We need to get rid of the driver that you have installed at the moment, because there is something wrong with it.
Self Build 64bit
4096 MB DDR3-SDRAM
Realtek on board
Cooler Master 1000w
Fans and fresh air,
Wireless
Wireless
Never fast enough
I use a Magnum.
Ok I've done as jfar has suggested and its not really working, doesn't seem to 'delete' the existing one and replacing with the new one downloaded. It simply tells me to select the FOLDER where driver software is located, and when I click next, it simply says that 'Windows has determined the driver software for your device is up to date.' [In the attached pictures, it goes from the first pic to the second in like half a second without doing anything]
Also, sorry for the frustration and thank yous for the continued support and patience [and being nice]. Somehow I thought no one responded hence the 'double post' (which really wasn't a double post lol). I've just changed the setting to 'Instant email notification' :D
I really want to save reseating for last, because I'm not too confident about opening up the PC and can't seem to budge the video card despite holding down the latch etc. As well as still having warranty [which may have been voided now, but who knows ;P] but that'll be a lot of extra fuss.
Thanks again, please continue to support and tell me what I can do.
