Odd problem with wireless connection...
dchaosblade
1:41 PM
Okay, so I've read around the forums and noticed that a lot of people have had a lot of problems regarding wireless connectivity - most of which were related to drivers...well, I've got a problem too, but I don't think it's my driver... As a note, I'm not using the one provided with the Windows 7 install (it didn't seem to work), instead using a driver I got online with Vista.
Some quick info: I am running both Vista and Windows 7 on one computer - dual booting between the two. The wireless adapter works in Vista but not in Windows 7.
I'm using a Linksys WUSB54G Ver.4 USB wireless adapter - It worked in XP, it works in Vista, but it doesn't seem to work in Windows 7. At first I had a driver problem, but quickly fixed that by following some advice in this forum. In my device manager the adapter appears, does not have a exclamation point or etc, and when I check the properties, it says "The device is working properly".
That said, when I check for any wireless signals, I don't see any (in Vista, I can see 2: my own and my neighbors). I've tried manually adding the network with all its info (SSN, WPA-2 Personal, and the key) but to no avail. When I rightclick and say to check for solutions it tells me to make sure to flip the switch on the side of my computer or use the function keys to turn on the adapter (as if I were using a laptop).
I've tried unplugging/replugging the adapter in, full restarts, turning off the powersaving thing where it may turn off the adapter, all with no luck. If anyone has any ideas, I'd appreciate the assistance.
Once again, I believe I have a working driver, but if someone has the same device and it works then feel free to point me in the direction of the driver you have and I'll test that one out just in case...
HP a6130n
Windows Vista x32, running Windows 7 x32 Beta 7000
AMD Athlon 64 x2 Dual Core Processor 5000+
ECS MCP61PM-HM
NVIDIA GeForce 8800 GT
HP w2007
Hitachi HDT736040VLA 400 GB SATA 3G 7200 RPM
HP multimedia keyboard
Logitech LX3 optical mouse (USB)
I had similar problems. Downloaded these drivers. All ok now. :)
http://www.sevenforums.com/drivers/2600-netgear-wg111v2-beta-driver.html
Dilithium Computers/Engineering (Myself) Star date 42.739285.5432.9
Win7 Ultimate x64 on Desktop / Win7 Ultimate x86 on laptop / Win7 x86 Starter on Netbook
AMD Phenom 965 X4 3.4Ghz cpu Black Edition
Gigabyte 790XT
12 Gb DDR3
Nvidea Gforce GTX 470
Onboard Realtek hi-fi
Lg 3D led 23"
Loads maxstore sata 1 & 2/ loads of partitions + 1Tb Hitachi sata 2. 256Gb Crucial ssd.
OCZ 700W GameXstream
Artec 10000
On board + many case fans
Logitech wireless K350
Inferno gaming mouse
Talk talk. 10Mb
My PC was hand built with matchsticks. xbox 360 controller. Printers,fax.........
Will that driver work on the x32 version? Cause the linked post says it's for the 64 bit; which - as I understand it - wont be compatible with the 32bit. I could install the 64bit but that'd be another big download and install =/
HP a6130n
ECS MCP61PM-HM
HP w2007
Sorry, yes its for 32bit & 64bit. Have edited the info now.
Gigabyte 790XT
12 Gb DDR3
Lg 3D led 23"
Artec 10000
Talk talk. 10Mb
No dice. When I use that driver, the device manager reports an error: Failed to start
Any other suggestions?
HP a6130n
ECS MCP61PM-HM
HP w2007
You could try the Realtek drivers site. They are for most make of adapters. :)
Gigabyte 790XT
12 Gb DDR3
Lg 3D led 23"
Artec 10000
Talk talk. 10Mb
I finally found a driver that worked after a lot of testing. Currently online on Windows 7. Yay! *goes off to get firefox*
HP a6130n
ECS MCP61PM-HM
HP w2007
Fault now fixed
Glad to hear your problem is sorted out. :)
Gigabyte 790XT
12 Gb DDR3
Lg 3D led 23"
Artec 10000
Talk talk. 10Mb
first time i use w7 to connect internet via wireless lan device. it's couldn't although all drivers complete install.
i try to solve what happen, and i found that windows firewall is my problem.
so i turn windows firewall off, then wireless lan device can connect to internet,
Goddddd......its very fast than i use vista!!!!!
and connection very stable too.
Acer Inc. Acer Aspire 4720ZG
Windows 7 Ultimate Release Candidate [build 7100]
Intel(R)Pentium(R)Dual-CORE [email protected] L2-Cache 1MB
Acer, Inc. Nestos Intel(R) Chipset PM965 Rev.C0
Apacer DDR2-RAM 2 GB
nVidia GeForce 8400M G DDR2-VRAM 128 MB
Realtek High Definition
Acer CrystalBrite LCD - Generic Laptop PnP
1280x800 pixels
Toshiba MK1646GSX ATA 160 GB
Synaptic TouchPad v6.5
2048/512 (Down/Up) ADSL-TOT-Thailand
HL-DT-ST DVDRAM GSA-T40N ATA DVD-Super Multi DL
802.11 B/G WLAN
Bluetooth(R) 2.0+EDR
After hours and days trying to troubleshoot my NO WIRELESS CONNECTION problem with my new Win7 notebook ASUS technical finally gave me the answer.
[Fn][F2] then click on antenna icon on screen. waalaa. I now have wireless connection(s). This is the softkey switch that turns off/on wireless ability. some computer have an actual switch on the front or side of the laptop.
Try it; can't hurt. Hope it helps
Asus P501J
win 7 premium
T4300
gma 4500m
4gb
15.6 hd/led
320gb
Exact same problem with Windows 7. The wireless card does not see any wireless networks. In fact, I cannot enable it [FN + F2] as the red X stays on. How can I download the driver being discussed? I tried following the links, but after ending up at the drivermax.com site and installing the product, there is no driver to download. Help!
Dell Inspiron 1750
Win 7 64bit
Interl centrino
4gb
i recently bought a vaio laptop vpc-f11dgx with windows7 64 bit
i could connect with it to the routers in my university but unfortunately after a few days it didnt work
it could connect like the past but it couldnt transfer data
i tried to set up the 32 bit windows but drivers of my laptop couldnt work on it
it happens to some of my friends that use 64bit but not others who use 32bit.
what is wrong with my computer?
what can i do?
i tried another 64bit windows but it was the same.
my email is [email protected]
please tell me what can i do.
corei7
64bit
corei7
sonyvaio
sonyvaio
geforce512
sonyvaio
sonyvaio
sonyvaio
sonyvaio
sonyvaio
sonyvaio
