pc hard lock ups need help
kurogane0017
3:29 AM
ok a few months back was getting hard lock up changed the psu to a corsair 850rm put a new heat skin on tryed a new drive put a evo840 ssd in turned the old drive to a slave then took the slave out and put a wester digital in tryed new ram ran disk check windows mem test tryed to one stick test will not crash on prime 95 or anyother benchmark tester tryed my 460 gtx super over clocked no use tryed removing intel smart connect because it was not working tryed to remove smart storage replaced the mouse just bought a new case called intel they have me down load a cpu check that they use to check if the cpu is damaged by heat or anything else tryed runing it 3 time it passed all the asrock said it sounds like the bios is set up wrong and its not everything is set for the mobo to auto ajust its runing on ahci or what ever its called it tryed everything i can think of so reinstalled windows 5 times about and just bought a new mobo because all i can think of is ether the bios needs updated or the mobo has some mess up on it wich is all i can think of sent the new board back because it was messed up when i opened it up so i will get the new one in in 2 days but my pc has a asrockz77extreme3 in it now ordered a msi z77g43 but waiting to flash the bios and put the new water cooler on it and put it in the new case just to make shore it works right if i do a bios up date dont work going to rma it to asrock and put msi in it and see if that fixes it tryed everything i couls think of anyone have anythought that can help me out
windows 7 home premium 64 biti7 3770muskin black list 1600 ghz and corsair 1600gh...760gtx4gb
custom build
i7 3770
asrock z77 extreme 3
muskin black list 1600 ghz and corsair 1600ghz ram
760gtx4gb
no board relteck
hp 2009m
samsung evo840 and wester d hdd 1 tb slave drive
corsair rm 850
saitek
steelseries
mse
firefox
Does your keyboard have any punctuation, paragraph, or capitalization capability?
Dell S2340M 23 inch IPS
1600 x 900
Antec Solo II
Microsoft 200 6JH-00001 USB
Pale Moon
yes but i found there windows errors in application
- Provider
[ Name] Windows Error Reporting
- EventID 1001
[ Qualifiers] 0
Level 4
Task 0
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2014-04-21T08:33:40.000000000Z
EventRecordID 3931
Channel Application
Computer jon-PC
Security
- EventData
919338740
5
AEAPPINV2
Not available
0
3
2
6.1.1.0
1033
73
0
a0f10bec-c92f-11e3-92e4-bc5ff484545c
0
Fault bucket 919338740, type 5
Event Name: AEAPPINV2
Response: Not available
Cab Id: 0
Problem signature:
P1: 3
P2: 2
P3: 6.1.1.0
P4: 1033
P5: 73
P6:
P7:
P8:
P9:
P10:
These files may be available here:
Analysis symbol:
Rechecking for solution: 0
Report Id: a0f10bec-c92f-11e3-92e4-bc5ff484545c
Report Status: 0
Fault bucket , type 0
Event Name: LiveKernelEvent
Cab Id: 0
Problem signature:
P1:
P2:
P3:
P4:
P5:
P6:
P7:
P8:
P9:
P10:
C:\Windows\LiveKernelReports\WATCHDOG\WD-20140416-1957.dmp
C:\Windows\Temp\WER-4369010-0.sysdata.xml
C:\Windows\Temp\WERB4EE.tmp.WERInternalMetadata.xml
C:\ProgramData\Microsoft\Windows\WER\ReportQueue\Kernel_0_0_cab_179ab4ee
Analysis symbol:
Report Id: d6f1fdd3-c5c2-11e3-b79c-bc5ff484545c
Report Status: 0
Event Name: BlueScreen
Cab Id: 0
Problem signature:
P1:
P2:
P3:
P4:
P5:
P6:
P7:
P8:
P9:
P10:
C:\Windows\Minidump\040714-7222-01.dmp
C:\Users\jon\AppData\Local\Temp\WER-8876-0.sysdata.xml
C:\Users\jon\AppData\Local\Temp\WER2338.tmp.WERInternalMetadata.xml
C:\Users\jon\AppData\Local\Microsoft\Windows\WER\ReportQueue\Kernel_0_0_cab_0a713081
Analysis symbol:
Report Id: 040714-7222-01
Report Status: 0
Fault bucket 177075623, type 17
Event Name: APPCRASH
Cab Id: 0
Problem signature:
P1: FlashPlayerPlugin_13_0_0_182.exe
P2: 13.0.0.182
P3: 533392a3
P4: FlashPlayerPlugin_13_0_0_182.exe
P5: 13.0.0.182
P6: 533392a3
P7: 40000015
P8: 00017fd0
P9:
P10:
C:\Users\jon\AppData\Local\Temp\WER196F.tmp.WERInternalMetadata.xml
C:\Users\jon\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppCrash_FlashPlayerPlugi_a4dc204a128ae687d27c46946d3e5b1dc6f79259_64b02b0b
Analysis symbol:
Report Id: d8fc8cd8-cc04-11e3-933a-bc5ff484545c
Report Status: 0
Fault bucket 37177378, type 22
Event Name: RADAR_PRE_LEAK_WOW64
Cab Id: 0
Problem signature:
P1: DayZ.exe
P2: 0.44.123.800
P3: 6.1.7601.2.1.0
P4:
P5:
P6:
P7:
P8:
P9:
P10:
C:\Users\jon\AppData\Local\Temp\RDR5808.tmp\empty.txt
Analysis symbol:
Report Id: 8e2740ee-cc23-11e3-933a-bc5ff484545c
Report Status: 0
Cab Id: 0
Problem signature:
P1: 3
P2: 2
P3: 6.1.1.0
P4: 1033
P5: 73
P6:
P7:
P8:
P9:
P10:
Analysis symbol:
Report Id: ac7f0468-c86d-11e3-b5d9-bc5ff484545c
Report Status: 0
Fault bucket 430232895, type 5
Event Name: MemDiagV1
Cab Id: 0
Problem signature:
P1: 4097
P2: Manual
P3: Deferred
P4: Pass
P5: Standard
P6: 0
P7: 0
P8: 330
P9:
P10:
C:\Windows\System32\LogFiles\MemDiag\MemDiag.bin
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\NonCritical_4097_5a27e5922fb4371dbf1644505a21a6d9e57040e3_139a32d2
Analysis symbol:
Report Id: ac53ef8c-baa9-11e3-a977-bc5ff484545c
Report Status: 0
Fault bucket 32970647, type 21
Event Name: MpTelemetry
Cab Id: 0
Problem signature:
P1: 2152759308
P2: unspecified
P3: ScanFile
P4: 4.5.216.0
P5: Microsoft Security Essentials (EDB4FA23-53B8-4AFA-8C5D-99752CCA7094)
P6: unspecified
P7: unspecified
P8:
P9:
P10:
C:\Windows\Temp\MPInstrumentation\client_manifest.txt
C:\ProgramData\Microsoft\Windows\WER\ReportQueue\NonCritical_2152759308_abc02d3b78ec1c12f71ae74b63bb71dfb6919b4_cab_03c198a6
Analysis symbol:
Report Id: 04e1bcb2-b9d0-11e3-9592-bc5ff484545c
Report Status: 0
Fault bucket 3707751480, type 5
Event Name: PnPGenericDriverFound
Cab Id: 0
Problem signature:
P1: x64
P2: PCI\VEN_10DE&DEV_1187&SUBSYS_27663842&REV_A1
P3:
P4:
P5:
P6:
P7:
P8:
P9:
P10:
C:\Users\jon\AppData\Local\Microsoft\Windows\WER\ReportArchive\NonCritical_x64_5b63b91d0793ec8657de7217decb652af12943_139a0186
Analysis symbol:
Report Id: b9e7b3a0-bb7b-11e3-a7b0-bc5ff484545c
Report Status: 0
Fault bucket 518506569, type 5
Event Name: ScriptedDiagFailure
Cab Id: 0
Problem signature:
P1: Microsoft Windows.NetworkDiagnostics.1.0
P2: 586382887
P3: 1.0.0.0
P4: Default
P5:
P6:
P7:
P8:
P9:
P10:
C:\Users\jon\AppData\Local\Microsoft\Windows\WER\ReportArchive\NonCritical_Microsoft Window_a73fbe76a631b444648ec316b3443d240686930_1399dee9
Analysis symbol:
Report Id: 090e1e04-c094-11e3-9b77-bc5ff484545c
Report Status: 0
custom build
i7 3770
760gtx4gb
no board relteck
hp 2009m
corsair rm 850
saitek
steelseries
mse
firefox
Additional information is required.
1. Download the DM Log Collector application to your desktop by clicking the link below
DM Log Collector.exe
2. Run it by double-clicking the icon on your desktop, and follow the prompts.
3. Locate the .ZIP file created on your desktop, and upload it here in your next reply.
picture.php
Golden Mk. I.4
EVGA NVidia GTX 560 1024MB
Realtek Integrated
1920*1080 and 1920*1080
1*Samsung 840 EVO 120GB SSD;
1*OCZ Vertex 2 60GB SSD;
1*Samsung F1 SpinPoint 1TB;
Logitech G110
Logitech MX518
dont want to sound dumb but how to u up load the zip just with the reg picture file loader there is 2 folders jons pc friday and sddubug file
custom build
i7 3770
760gtx4gb
no board relteck
hp 2009m
corsair rm 850
saitek
steelseries
mse
firefox
custom build
i7 3770
760gtx4gb
no board relteck
hp 2009m
corsair rm 850
saitek
steelseries
mse
firefox
i changed to an ssd chaned my psu changed my g card changed my slave drive and tryed new ram
custom build
i7 3770
760gtx4gb
no board relteck
hp 2009m
corsair rm 850
saitek
steelseries
mse
firefox
just ordered a new motherboard
custom build
i7 3770
760gtx4gb
no board relteck
hp 2009m
corsair rm 850
saitek
steelseries
mse
firefox
here is the mini dump cant find anything else
custom build
i7 3770
760gtx4gb
no board relteck
hp 2009m
corsair rm 850
saitek
steelseries
mse
firefox
here is the mini dump and all the other files for it errors
custom build
i7 3770
760gtx4gb
no board relteck
hp 2009m
corsair rm 850
saitek
steelseries
mse
firefox
Well since you changed all the hardware, its better to wait for the next BSOD.
Golden Mk. I.4
Realtek Integrated
Logitech G110
Logitech MX518
i have changed the ram and psu and the ssd got wiped so the only thing that was changed after was the i changed the ram u think i should install the new motherbaord tomarrow its and msi 43g and reformat the ssd drive and see if that fixes it
custom build
i7 3770
760gtx4gb
no board relteck
hp 2009m
corsair rm 850
saitek
steelseries
mse
firefox
You need to slow down a bit...and stop duplicate posting.
My suggestions are:
1. Install all your new hardware when it arrives
2. Install Windows and other software and update fully
3. If you experience a BSOD after 1 & 2 above, do this and nothing else:
picture.php
Golden Mk. I.4
Realtek Integrated
Logitech G110
Logitech MX518
there are 5 bios updates for the motherboard its in it right now u think i could be the bios need updating
custom build
i7 3770
760gtx4gb
no board relteck
hp 2009m
corsair rm 850
saitek
steelseries
mse
firefox
Only if it address/fixes a specific issue you are experiencing.....if not, leave the BIOS alone.
Golden Mk. I.4
Realtek Integrated
Logitech G110
Logitech MX518
well it say gpu cpu ram and usb conpatibility
custom build
i7 3770
760gtx4gb
no board relteck
hp 2009m
corsair rm 850
saitek
steelseries
mse
firefox
but i am just going to stick my new board in tomarrow reformat and will post my findings to u if it fixes it i have a new case and have a water pump in it so if its heating it will fix it
custom build
i7 3770
760gtx4gb
no board relteck
hp 2009m
corsair rm 850
saitek
steelseries
mse
firefox
You need to take that information in the context of which CPU and GPU you are installing.
There is no point in referencing your previous problems until all hardware is installed, Windows installed and updated, and all drivers updated. For all intents and purposes you are starting over, so assume there are no problems.
Golden Mk. I.4
Realtek Integrated
Logitech G110
Logitech MX518
