chaoscreater
- Local time
- 10:54 AM
- Messages
- 11
Hi guys, first off i'm running Windows 7 32bit build 7600 (full and legit version).
I'm having 3 annoying problems, the first is the "Getting Started" window that pops up everytime at the desktop straight after the welcome screen, this happens everytime when i start windows. In Windows Vista, there is an option on the bottom left to disable it so that it never shows up again. However, i can't find that option anywhere.
I did some Googling and the solutions i found don't work either, such as running the command "msconfig" and finding the service that starts the Getting Started screen, there isn't one on my list, and i went to user accounts and there's no option to disable the screen on Windows 7, but it's there on Windows XP & Vista.
So ya, that's one problem, the 2nd problem is the Pin to Start menu option, it's not there. I already looked at this topic here:
http://www.sevenforums.com/tutorials/5736-start-menu-enable-folder-library-pin-start-menu.html
and applied the registry patch, but it didn't work. I did some Googling and used other registry patches and they don't work either.
and the 3rd most annoying problem is the item selection highlight. When you select any icon on Windows 7, it should be highlighted, i.e the icon background should be highlighted and the default normal colour is light blue or dark blue. But on Windows 7, it's different, it's transparent and it's hard to see what items you selected, especially if you have multiple icons selected. If you don't understand what i mean by this, try select Windows Classic theme and then just select an item on your desktop or something, and the background should be dark blue. If you use an aero theme or whatever theme, it is most likely glassy and transparent.
This annoys me a bit since it's hard to see what you have selected, and it doesn't happen on XP or Vista. I tried turning transparency off and adjusted the options and it didn't change the icon background to the default colour.
So ya i'm out of ideas, if anyone could please help me with these problems i would be greatly appreciated.
- Windows 7
- i7
- Motherboard
- Asus Rampage II
- 4GB
- Graphics Card(s)
- Radeon HD 5870
- Monitor(s) Displays
- Samsung 50' Plasma (using my TV)
- Hard Drives
- Seagate Barracuda 2TB
- PSU
- Acbel 800W
