Please help - network connection problems
tomelliott1984
12:34 AM
Dear all,
I'm having trouble connecting one of my laptops to my router. I've tried connecting using the dsl cable and wireless but neither work. The internet and router are both working fine (i'm using it right now from my work laptop).
I have windows 7 and everything was working fine last night. I then installed AVG free antivirus and I've not been able to connect since.
Can anyone help suggest any way of fixing this? Is there a way of resoring all settings to 24 or 48 hours previous? My technical knowledge of computers is very small so any help whatsoever would be gratefully received.
Thank you,
Tom
Dear all,
Thank you,
Tom
Hi Tom and welcome
Since this problem started after AVG the simplest method would be to uninstall it. If you do and it doesnt go away you can always reinstall avg laterKen
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
If that doesn't work, maybe try doing a system restore.
Lenovo ThinkPad T60
Windows 7 Ultimate 64Bit
GenuineIntel Intel(R) Core(TM) DuoCore T2400 @ 1.83GHz
Intel(R) 82801G (ICH7 Family)
2.00 GB
Mobile Intel(R) 945 Express Chipset
ThinkPad Display
1400x1050
100Gb SATA
Standard Keyboard
HID-compliant Mouse
Cable Broadband - 54Mbps
Intel(R) PRO/1000 PL Network Connection
11a/b/g Wireless LAN Mini PCI Express Adapter
Thanks for the responses... I've uninstalled AVG and attempted to do a system restore to my previous checkpoint but neither have worked. It's bizarre, although everything is working correctly, my laptop just cannot connect to the router.
Is there a way of starting from scracth again as if I were connecting to my router for the first time?
Tom
Absolutely. There should be a reset button on your router. After you reset the router, connect to it using cable connection, and to it's control panel using IE ie. http:\\192.168.1.1 (or whatever default IP it is for your router). Logon is username=admin, password= blank (or whatever it is for our router model). Once you are in, setup security for your router, and then create your wireless network.
Lenovo ThinkPad T60
2.00 GB
ThinkPad Display
1400x1050
100Gb SATA
Standard Keyboard
HID-compliant Mouse
check your bios and make sure your wireless card is enabled
Windows 7 Ultimate Signature Edition
Intel Core i7 Extreme 3.33GHz
EVGA X-58 SLI Classified
12GB DDR3
2x EVGA 285 2GB in SLI
Creative Labs X-Fi ExtremeGamer
30" Viewsonic
2x1TB Western Digital 7200RPM in RAID 0/1TB WD My Book External HDD
Thermaltake 1000w supporting quad SLI
Thermaltake Armor Full Tower
Thermaltake V1 CPU+DIY Liquid cooling
