Possible power supply fan issue w/ Win 7
Zathras
10:33 PM
I haven't kept up with power supply technology at all, on my old PCs that ran Win 95 thru XP, I generally had 250W-450W power supplies that were pretty noisy. The power supply fan ran all the time, and expelled quite a bit of warm air.
On my new PC with Windows 7, I have a "700 watt" power supply that seems to work OK, but I notice that after Windows loads the power supply fan seems to stop running, or runs so slowly that you can't hear it. There is very little air movement coming out. During bootup the power supply fan (I think) whirs and hums like I'd expect; but the instant the Windows7 logon screen comes up, the fan goes silent. Are power supply fans supposed to be variable speed or load-dependent, now? Is the power supply tied in to the OS somehow?
Thanks... although everything seems to be working fine, I don't want to fry my PC and/or power supply.
Win7 Home Premium x64Intel Core i7/8604 GB PC 1333Nvidia GTS 250 (1 GB mem)
Intel Core i7/860
Gigabyte GA-P55M-UD2
4 GB PC 1333
Onboard Realtek ALC888B
Western Digital 500 gig, 7200 rpm
700W
You didn't specify brand/model of the PS, so I can't make a flat statement, but yes many PSs have internal thermal controllers which only run the fan when needed. I'm not aware of any direct control of this fan via the OS, but when any Windows OS finishes loading they power requirement would lower, thus reducing the need for the fan. My PS has both a bottom fan for intake, and a back fan for exhaust, and only the intake fan is thermally controlled. I might be somewhat more concerned if the exhaust fan wasn't spinning.
W7x64 Pro, SuSe 12.1/** W7 x64 Pro, XP MCEPhenom II 1090T w/Noctua NH-D14 /**4400+ X2 w...2 x 2GB Patriot PGS34g1600LLKA/**4x1GB Corsai...EVGA GTX460 SC/**EVGA 8800GTS
DIY
Asus Xonar D2X/**Xonar D1
HAF922/**Antec 1040IIB
3.3Mbps
(** = 2nd rig)
