Solved Problem with wireless adapter, wireless network disconnects abruptly
AvinashS
9:26 AM
Mine is Dell Inspiron 3537, Os: Windows 7 Ultimate x64. My laptop wifi works fine for some period of time, but suddenly the current wireless connection gets disconnected and no wireless networks appear in the list. The network connection icon in taskbar changes to no network connection (small monitor with yellow exclamation icon). The wireless adapter is still enabled only.
Well i found a way to bring back the connection and to show the available wireless networks by disabling and enabling the dell wireless adapter under "change adapter settings" in Network and sharing center. But this problem keeps repeating at unpredictable intervals and i have to disable and enable the wireless adapter everytime!. Please help me with a solution.
I have already tried the following,
1. Re-installing,updating wireless network drivers.
2. Re-installing entire OS with full format of all hard drives.
3. Disabled (unchecked) "allow computer to turn off this device to save power" option under power management tab of dell wireless adapter properties.
4. Changed the power saving options for wireless adapter to "maximise perfomance" for both on battery and plugged in modes.
Having tried all these still no luck, the problem persists. I borrowed a digisol wireless USB adapter from my friend. this works fine all the time with no issues.
I have no idea why mine is not working properly. please do help.
Windows 7 Ultimate x64Intel Core i5-4200U CPU @ 1.60 GHz 2.30 GHz6GB DDR3Intel HD Graphics (770 MB), AMD Radeon HD 867...
Dell Inspiron 3537
Dell Inc. 07TX6D (U3E1)
6GB DDR3
Intel HD Graphics (770 MB), AMD Radeon HD 8670M (2048 MB)
Seagate SATA 1TB
Well I found a solution myself. I suspected it to be a hardware problem and so I took my laptop to dell service center. They opened the keyboard panel and checked if there is any problem in the wifi module. Since no problem was found, they just removed it and re-fixed again. Now its working flawlessly!! haven't experienced the above stated problem again. :)
Dell Inspiron 3537
6GB DDR3
Seagate SATA 1TB
