Problem with XBOX 360 wireless controller
Zydd
6:32 AM
Hello,
I'm unable to connect my XBOX 360 controller to PC.
When I connect to different USB ports I get no green light on the receiver and it's not showing in Device Manager.
When I try to reinstall the software/drivers from CD, it says it's already installed and suggests removing it before reinstallation. However I'm unable to find XBOX accessories on the list of installed programs and have no idea how to find it otherwise to remove. This controller used to work just fine like a year ago, I don't know what's going on now.
custom
i5-3570k
Gigabyte Z77-HD3
2x4GB
HD 7870
OCZ Agility3 128GB
WD Blue 500GB
AVG
Hi Zydd, I use the same setup as yourself, in device manager, your wireless receiver should show up under "Microsoft common controller for windows class" and under there should be "Xbox 360 wireless receiver for windows" as shown in the screenshot below:
however, your device might not be drawing enough power to efficiently work the way you wanted or intended, you can check this by going to device manager and going to "Universal serial bus controllers" and look for USB root hub and right click > properties > power, if it's drawing less than 260 mA then you will need to find a port which supports USB 2.0 at 500 mA.
Intel Q6600 @ 2.6Ghz
Evga NF78-CK-132-A 3-Way SLI
4Gb DDR2 Corsair Dominator @ 800Mhz 5-5-5-15
EVGA 560 GTX SC FTW 1GB
Realtek HD 7.1 Audio, Plantronics GameCom780 7.1 Headset
Dell S2409W
SanDisk SDSSDHII-120G-G25 120GB SSD
Samsung 7200RPM 750Gb SATA
Samsung 850 EVO 120GB SSD
Western Digital Green 1TB 7200RPM
Xigmatek 750W Quad sli quad core 80% eff
Antec 900 Gaming Case
Zalman CNPS9700-NT NVIDIA Tritium
Logitech generic keyboard, MS wireless keyboard
Razor Lachesis Banshee V2 Blue, 4000DPI, MS wireless mouse
152Mb Virgin Media Fibre Optic
Wireless Gaming Receiver for Windows, Wireless Xbox 360 Pad
Hello Mr. Needs
The problem is I'm unable to find "Xbox 360 wireless receiver for windows" in the Device Manager. Still when I try to run a fresh installation of Xbox Accessories/drivers, it says that I need to uninstall the old one first however I cannot find it on the program list either.
custom
i5-3570k
Gigabyte Z77-HD3
2x4GB
HD 7870
OCZ Agility3 128GB
WD Blue 500GB
AVG
Hello Mr. Needs
I understand Zydd, but the driver won't load if it's not got enough power, it's a hungry horse this wireless receiver ;) I would suggest trying a USB port at the back of your computer that is rated for 500mA, if the xbox accessories program is reporting that you've already installed then it will be fine to leave that installed, the problem is detection of the accessory itself.
Dell S2409W
10 Pro x64
Ryzen 9 3900X
Asrock x370 Tachi
64GB(4x16GB) DDR4
EVGA 1080ti FTW3
ASUS Xonar Essence STX (V4 Bursons), ODAC rev B, NFB-11, O2
3xASUS PB278Q/R, Optoma HD142X
3x1440p, 1080p
512GB 850 EVO(OS, Programs)
4TB (Movies)
3TB (Downloads)
3TB (Programs)
1TB HDD (Games)
2x6TB R1 (videos)
AX760
Fractal Define R5
NH-D15S
Massdrop Ctrl with Box Navy's
G903, Alioth XXL Mat
MBAM, ESET
Canary 64 Bit
I also own a Thinkpad P50 Xeon 4K, X220T, X1C5
