Problems connecting wireless printer
Whippet
1:38 PM
I've a Dell Inspiron 1750 & a Canon MP560: they're next to each other on my desk.
I've been through the printer installation & select the network & wireless option, but the Dell can't find the Canon.
Trying from the other end, I go through the connection option on the Canon & when it can't find the Dell automatically it asks for the access point name.
I've tried entering the SSID - that didn't work. So I tried the network key (being careful with upper/lowercase) but that doesn't work either. The printer can't find the Dell.
Both the Dell & the printer happily find my wireless router, so the wireless 'thingies' must be working OK.
What the heck am I doing wrong?
I'd be glad of any help.
Thanks,
Jackie
dell Inspiron 1750
windows7 home premium 64bit
Pentium dual core 2.3 GHz
2.0 GB
Hi Whippet. Welcome to the Forum.
First, make sure that the wireless printer is set up correctly (sorry if this is redundant).
On the printer setup settings, make sure the SSID is correct, the router's security protocol, and the long encryption key - all in the right upper/lower case.
Check to see that the "Wireless Connection" icon is illuminated and that you have some bars.
Next, in Windows, click on the Network icon in the taskbar and open "Network and Sharing Center". On the top line is "View your basic...", and click on "See Full Map". See if a wireless device is showing up there.
If it is then you have no network problem, just a driver installation problem. Let us know and we can take it from there.
Also: are you installing the printer driver from the printer CD or from a download?
Home Built - Jan 2013
i7-3820
Asus P9X79-PRO - Bios 4608
GSkill F3-14900CL9Q - 16GB
On board Realtek ALC898
Acer S271HL
#1- Samsung 840 Pro Series
Corsair Obsidian 550D
MS KC-0405
Intellimouse 5-button
56 Mbits/Sec (on a good day)
Avast & Malwarebytes
Asus DVD - DRW-24B1ST 24X
Most wireless printers require the software be installed first and then the USB cable attached to a computer for the internet connection sharing to be setup.
HP 17-ak0xx, dv7 3173nr
Win7 Home Premium x64 W10Pro&Home
A12 9720p 4+8 TurionII M520
HP 3839
6GB 8GB
R7
24" sa550
1600x900 1920x1080
Logitechx2
120Mb/s down 12up
Exactly right, once that is done then you can unplug usb cable and print wirelessy to your hearts content.
Custom built
Windows 7 Ultimate 64 bit
AMD Phenom II X4 965 Black Edition
Gigabyte GA-MA790X-DS4
GSkill 4 X 2 GB PC 8500
XFX Radeon HD 6790 D
On board RealTek HD
Dual monitors:Samsung SyncMaster S20B300
1600 X 900
Seagate Barracuda 1TB (primary)
Seagate Barracuda 2 X 320 GB
Ultra X4 750 watt fully modular
Thermaltake Overseer RX 1 full tower
Core-Contact 92 mm CPU Cooler
Logitech G510
Razor DeathAdder
50/5 Mbps UL/DL
Optical: Super Muliti DVD burner w/lightscribe, Hauppauge WinTV HVR-1800
Thank you for the replies.
Before I start to check step by step what you suggest, I'd just like to ask how this wifi connection between PC & printer is supposed to work.
Do the PC & printer talk directly to each other, or do they communicate to each other through my internet router?
I need to have a vague understanding of how this wifi connectivity works.
Thanks for your welcome to the forum - it's full of real gems for a W7 newbie.
Jackie
dell Inspiron 1750
2.0 GB
self build
amd phenom x4 9600
asus m2n32-sli deluxe
corsair twinxs 2x2gb
2x nvidia 1gb 8500gt
onboard
23" PB Viseo 233d
maxtor sata 500gb
maxtor sata 320gb
fujitsu sata200gb
oryxx tornado 750w
thermaltake xaser lll
artic freezer64 pro + 7 case fans
Oh amazing!!! I've just done my first wireless print :party:
You'd think I'd discovered the wheel, I'm so happy.
I've been trying for days & days to do this, without understanding that the PC & printer talk to each other through my router.
Eureka
Many thanks to all who helped.
Jackie
dell Inspiron 1750
2.0 GB
