Problems...need help from experts
damien007
12:12 PM
  • int15
my tune up utilities detected problems with int15 that the device is not working properly. when i checked the device manager, non-plug and play drivers int15, this message i got " the system encountered the following error while attempting to start the service. the system cannot find the file specified. how can i fix the int15? it cannot be updated....i don't know if this is related to the problem that my other programs, like ACDSee, FIFA game, encarta student etc, although they are still installed, and their installation folders still intact, they are not opening properly and they are requesting to reinstall especially the encarta.
  • explorer.exe
all of a sudden the task bar freezes....then when i restart the explorer.exe, the task bar doesn't move back to its non-freezing state............another explorer.exe related problem, everytime i shut down the laptop, explorer.exe is preventing the shut down, if i tried to force the shutdown, it is stuck in the logging off then freezes, it never shut down.
  • DVD-ROM driver
when burning data, it functions well but when i place a DVD like DVD with movies, it cannot read the dvd as if there is no dvd, i think there is a problem in the driver, is there a good driver for DVD rom?
please help me, and please use words that even newbie like me can understand, thank you
Acer Aspire 4736z
Pentium(R) Dual Core
Acer Aspire 4736Z Motherboard MB.PFZ02.002 MBPFZ02002
DDR2
Mobile Intel(R) 4 Series Express Chipset Family
HDD
microsoft security essentials
W530-3630QM1
windows 7 home 64bit
INTEL-CORE I7
16GB
750GB
i'm already done the sfc /scannow in the command prompt many time already...
ok, im downloading the 2programs....is it really necessary to remove tune up?....thank you for the reply
Acer Aspire 4736z
DDR2
HDD
What was the Result of the Scan ? .... You do not need such a Program as that it will not Speed Up or Optimize Your PC..... My guess is it has already done damage to your Registry ...
W530-3630QM1
INTEL-CORE I7
16GB
750GB
I'm using it for years already,but this time,i dont really know what happened,but i already uninstalled it, then i scanned using adwcleaner,then after the restart,it hangs on the desktop,so i cannot scan using malwarebytes,i can't even refresh, but using safemode,there is no problem,what will i do next sir?
Btw,there is 1 thing that that i remembered being cleaned by adwcleaner,the roboot64.exe....
Sir,i remembered,all my problems above started when i installed the update of realtek,after the restarted,there came these problems
Acer Aspire 4736z
DDR2
HDD
