Problems when using e-SATA cable with my External HD
shadowman
11:13 AM
OS: Windows 7: Home Premium 64-bit
External HD: Western Digital My Notebook Home Edition 1 Tb Model# WD10000H1CS-00
Motherboard: ASUS M2N-SLIDELUXE
Problem: When I use the e-sata cable on my external HD half of the time I'll experience data corruption or what seems like data corruption exg. pictures will not open in Irfanview (gives a missing handle error etc.), picture thumbnails are wrong and show incomplete pictures. After I took the e-SATA cable off and put it back onto the setup I had before using the firewire cable I don't have the error handles and files not loading etc.
I like how the e-sata cable is a bit faster than the firewire cable but this is a problem I can't seem to understand. Can someone tell me what to do in this scenario?
I've seen things about the JMICRON drivers or something like that but I don't want to mess around with anything especially essential drivers if I don't know what I'm doing. also I might add that I am running everything in IDE. AHCI wouldn't work when I changed to that in the BIOS. I got a "cannot locate operating system" error.
Windows XP Home Edition 32-bit
could someone please help me try to understand what is wrong?
Hi shadow,
Can you try a another cable, possibly shorter? Long cables are known to produce corruption.
Last fall, I was getting corruption and errors logged due to my external. Replaced the cable and the problem went away.
If you do need help with Jmicron, I can assist you with that. I'm off to work soon, but will check back here later.
Windows 7 Professional 64i7 8608GB Corsair CMX4GX3M2A1600C9 DDR3 1600(2) Nvidia EVGA GTX 470 SLI
self built
i7 860
ASUS P7P55D-E Pro /onboard SATA 6Gb/s USB 3.0
Onboard VIA VT1828S 8 channels
ASUS VW266H 25.5" HDMI Widescreen LCD and HP vs19 LCD 19"
1920 x 1200 : 1280 X 1024 dual
Intel X25-M 80GB SSD (boot)
Seagate Barracuda 80GB
Western Digital Caviar Black 500GB
Asus DRW-24B1ST/BLK/B/AS
COOLER MASTER Silent Pro 1000W
LIAN LI Lancool PC-K62
Prolimatech Megahalems with Scythe "ULTRA KAZE" 120
Saitek
Microsoft Optical comfort mouse 3000
Comcast Ultra tier 30/5
I just bought the cable though so I think its unlikely :o
It's probably NOT the cable, but instead, the motherboard.
I have an older A8N32-SLI ASUS mobo and could not get the E-SATA to work reliably on it, either. I spent months reading the ASUS forum, but no one came up with a reliable solution.
It's likely a problem with the E-SATA chipset used on the ASUS boards.
Win7 Pro 32-bit, Win8 Pro 32-bitAMD Phenom II X6 1090T4GB ddr3 1300AMD HD 4290 onboard
Gigabyte
4GB ddr3 1300
AMD HD 4290 onboard
Builtin Realtek HD Audio
1920x1200/1920x1080
Kingston 256GB SSD
Logitech Illuminated Keyboard
Logitech M705 wireless mouse
Norton Av 2013
IE v10
