Problems with New Realtek Card RTL8139/810x and wifi connection
lanni777
12:21 PM
Recently my network connection hardwired to the motherboard went bad. Installed a Realtek RTL8139 network card and now cannot get internet on the PC and wireless at the same time. Router and modem checks out. The original hardwired connection (to the motherboard) has been disabled. Any suggestions?
windows 7 64 bitIntel 2 duo processor E63008.00 GB
Gateway GM5420
windows 7 64 bit
8.00 GB
Win7 & Win8 64bitIntel i5
Lenovo Desktop/Samsung Laptop
Win7 & Win8 64bit
Intel i5
Charter-20 Mbps
FF, IE9 and Chrome
Verified NIC is present.
1. Not sure, thinking it's a wired prob, no internet on desktop when router plugged in, but have wireless capability, and when modem directly plugged to computer, I have internet on desktop, but of course no wireless.
2. ISP is Cox
3. Cable
4. Modem is a Motorola Surfboard SB5101 router is a Netgear G54/N150
5. McAfee through Cox
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Windows\system32>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Leah-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection 3:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek RTL8139/810x Family Fast Ethernet
NIC
Physical Address. . . . . . . . . : C8-3A-35-D9-EF-A7
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 192.168.1.5(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Saturday, August 10, 2013 9:07:55 AM
Lease Expires . . . . . . . . . . : Sunday, August 11, 2013 9:07:56 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 8.8.8.8
8.8.4.4
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:6abd:2036:b93:bb9c:6b3e(Prefe
rred)
Link-local IPv6 Address . . . . . : fe80::2036:b93:bb9c:6b3e%11(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.{BCABC212-E5A9-4C12-A933-C50AF798EAA3}:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Thanks!
Gateway GM5420
windows 7 64 bit
8.00 GB
Thanks for providing all info needed, it's quite helpful.
Can you please try disabling the McAfee Service? Click on the Start button and type Services on the Search field, locate McAfee Service and temp disable it.
Also, let's change the DNS back to Auto DNS, you are using Google DNS.
Change TCP/IP settings
Another update will be appreciated.
Win7 & Win8 64bit
Intel i5
Charter-20 Mbps
FF, IE9 and Chrome
