Problems with power plans
kershner25
12:53 AM
All my Windows Vista-on based desktops have always had problems sleeping/turning the monitor off. I can usually pull off a scheme for a while after a clean install but eventually it will regress to the point where the schemes just flat no longer work. On my most recent format, a Windows 7 64 PC, I am now at this point. I set a power plan to turn the monitor off after 10 mins and go to sleep after 20, but the computer does neither after the appropriate amount of time. This also happens on my girlfriend's current Windows Vista 64 machine as well.
I remember hearing about the potential for various programs to interfere with sleeping, but I was wondering how I would go about diagnosing which program, or what in general, is interrupting my PC's sleep/monitor off cycle?
Windows 7 64
Intel Q9400 OCed to 3.4GHZ
Biostar TP45HP
OCZ Reapers 2x2gb
Nvidia GTX 260
Seagate 640GB
Corsair 550W
Sunbeam Core-Contact Freezer
I wonder if the anti-virus could be the culprit. What A/V are you using? Try disabling it, for the time being, and see if your problem goes away.
What other programs are there that you and your girlfriend both use?
Windows 7 Professional x64
Intel i7 2600K OC'd @ 4620 MHz
Asus P8Z68-V Pro
16GB GSkill Sniper 2133 Mhz (4x4GB)
EVGA GeForce GTX 480 SuperClocked+
2x Acer S273HLbmii 27"
2 x 1920x1080
64GB Crucial M4 SSD
Storage: Hitachi 1TB 5400RPM, Samsung 1.5TB 5400RPM
Corsair HW Series 750w (modular)
Cooler Master HAF 932 Advanced Blue Edition
CM Hyper 212+ CPU cooler, 3x 230mm + 1x 140mm case fans
Logitech MK320 (wireless)
30 Mb/s : 2 Mb/s
Dell XPS 420
6 gb
ATI Radeon 256MB HD3650
Intergrated 7.1 Channel Audio
Dell SP2009W 20"
640 GB Serial ATA Hard drive
Fan
Dell USB Keyboard
Dell Premium Optical USB
DSL 2.85
I just turned off both AVG 9.0 and Windows Defender and set my Power Plan to: monitor off after 1 min, sleep after 2 mins just to test it out. Still no dice, should I reset and try?
Windows 7 64
Biostar TP45HP
OCZ Reapers 2x2gb
Nvidia GTX 260
Seagate 640GB
Corsair 550W
Dell XPS 420
6 gb
Dell SP2009W 20"
Fan
Dell USB Keyboard
DSL 2.85
