jaaqureshi
- Local time
- 2:58 PM
- Messages
- 2
Hi
im having problems with my wifi network.Im using a dell laptop with windows 7 64 bit op sys . For some reason my wifi disconnects after a an hour or so or it doesnt even connect when i open up my latop and try to connect to my network.When i do occaisonaly connect my signal strength is full but after 30 minutes it disconnects again. Can you guys tell me what test I should run and copy and paste here to help you guys find the problem? Thnks in adance!!
Problems
-wifi doesnt connect
-takes a long time to connect when it does connect
-only connects when i turn of my router and turn it back on.
-another laptop, a pc and 2 phones that all connect through wifi all work while my laptop doesnt so it isnt my router.
-I took my laptop to my college to use it there and it didnt work on their network either
when i run this wifi test on my computer it always fails on either ping test(defuault gateway )or association test.
Btw will you guys tell me a few ways to isolate what the problem is.Should i connect via ethernet cable.And since 5 other wifi devices are working and mines doesnt that should also isolate the problem.thnks
Problems
Windows 7 64 bitintel(r) core(tm) i5-2450m cpu @2.50ghz400 gb
- Computer type
- Laptop
- dell model-Inspiron N7110
- Windows 7 64 bit
- intel(r) core(tm) i5-2450m cpu @2.50ghz
- 400 gb
- Browser
- mozzilla firefox
