Realtek 5.1 speaker system problem
adriansaez
6:28 PM
I have a 5.1 speaker installed and am currently running win7...i have used this 5.1 speakers from my previous xp...when i try to test the speakers, all are making sounds....but when i play music and watch movies only the front speakers and the bass are working...it doesnt make sense at all....i tried looking at one of the similar problems to this but when i right click on the jacks i only get one option and it doesnt do anything at all....pls help me on this...i know you can solve this....pls...
Core2duo 2.80Ghz
XFX610i
2GB 667
Nvidia 9500GT Inno3d
On-board 6channels
17in CRT
(2) 80Gb WD IDE
XP, Vista, W7 64bit Home Premium
Intel Core Duo 6850 3.0 ghz @ 3.7 ghz
Asus P5E
4GB Corsair DDR 2 PC-6400
Ati 4870 1ghz
Supreme FX 11
View Sonic VX1962wm
1680 X1050
3 Seagate Sata Drives 160gb 250gb 500gb
Thermaltake 600 watt
NZXT Alpha
3X120cm Fans
Microsoft Digital Media Pro Keyboard
Microsoft Wheel Mouse Optical
1.5Mb to 8Mb/384k
thats the latest driver...and if you notice at the system properties the other jacks are not highlighted....i really cant figure out why...but they all make work when im testing them...
Core2duo 2.80Ghz
XFX610i
2GB 667
On-board 6channels
17in CRT
(2) 80Gb WD IDE
pls guys I need help :cry:
Core2duo 2.80Ghz
XFX610i
2GB 667
On-board 6channels
17in CRT
(2) 80Gb WD IDE
Cheap $399.00 E-Machine
Windows 7 Pro & Vista Home Premium
Athlon 64 3800+ (Orleans) 2.40GHz
Winfast
2GB DDR2 RAM DIMM
NVIDIA GeForce 8500 GT 512 MB memory HDMI out
creative X-Fi Exteme 7..1 channel
Acer V223W 22" widescreen DVI
WDC WD5 500GB
WDC WD25 250GB
OCZ 550 watt
Gateway
2 fans
Sony Vaio
18MB/s down - .72MB /s up
i've tried it once but it doesn't take effect...ill try downloading the codec awell...
Core2duo 2.80Ghz
XFX610i
2GB 667
On-board 6channels
17in CRT
(2) 80Gb WD IDE
do i have to download the ATI HDMI?????or the 3D SoundBack???are they codecs???
Core2duo 2.80Ghz
XFX610i
2GB 667
On-board 6channels
17in CRT
(2) 80Gb WD IDE
5.1 Sound
Are using "digital" output from Sound Card? I had a similar problem with my SB 5.1 but got it set "buried in speaker properties". Works ok now:D
custom build
WinXP / Win 7 / Win 8.1 64bit Dual Boot
i7-4770K
Asus Z87-A
16 gb G.Skill Ripjaws
on board 4600
On Board Soundmax HD
Dell 19" Flat Panel
1280x1024
Samsung 840 Pro 512gb SSD
WD1001 Caviar Win 7 Boot
WD500 Caviar Win XP Boot
2xWD500 Caviar (Raid 0)
WD750 Caviar (Backup)
Aerocool StrikeX 800w x2
Aerocool Strike X
Air
Microsoft Wireless
Microsoft Wireless
Cable
Asus 12x Blu-ray writer
Winfast
2GB DDR2 RAM DIMM
WDC WD5 500GB
WDC WD25 250GB
OCZ 550 watt
Gateway
2 fans
Sony Vaio
You may have two sound boards on the system...one motherboard integrated and the other a sound controller slotted to the motherboard bus. Windows is supposed to be smart enough to sort this out and disable one or the other, however there are occassons when this is not the case.
I too have athe exact problem with a flight similator station I built that has 5.1 w/ subwoofer. I have had it six months and have only been able to get the integrated sound working correctly OR just the two front speakers of the 5.1...no bass, no sub-woofer, no mid. When I got the mid, bass and sub going the front two speakers would stop working. I just gave up and have resided myself to just getting teh sound through the integrated sound by way of the motherboard.
I cannot offer any help that makes sense or solves the problem you are having but I can certainly share your pain.
DELL / Alienware M17x
Windiows & Home Premium
Intel® CoreTM 2 Duo P8700 (3MB Cache, 1066MHz FSB)
6GB DDR3 - 1333Mhz
SLITM Dual 1GB GDDR3 NVIDIA® GeForce® GTX 260M7
Internal High-Definition 5.1 Surround Sound Audio
17-inch WideUXGA 1920 x 1200 - (1200p) LCD
640GB 7,200RPM - RAID 0 (2x320GB)
If you have 5.1 that's ;digital sound you;; need the High Definition Codec.
Winfast
2GB DDR2 RAM DIMM
WDC WD5 500GB
WDC WD25 250GB
OCZ 550 watt
Gateway
2 fans
Sony Vaio
I'll have to check my drivers out...there is a good possibility I dont have that high-def codec since the 5.1 was "attached" and installed in a subsequent separate action from the windows install.....coupled with the fact the 5.1 was manufactured prior to Vista / Windows 7 being designed.
6GB DDR3 - 1333Mhz
quite a pain in the ass though....im dealing with it for now... ill just have to wait for windows 7 fix updates then...hmmmm..thanks guys....
Core2duo 2.80Ghz
XFX610i
2GB 667
On-board 6channels
17in CRT
(2) 80Gb WD IDE
