Realtek 8185 wireless connection problem in w7 x64
Bruce
12:37 AM
Hi people
I have recently bought a new computer. It originally came with vista x64 and I have recently upgraded this to windows 7 x64.
Both on windows vista and windows 7 I have been having wireless connection problems with my Realtek 8185 Extensible 802.11b/g Wireless Device
On Vista the problem could be fixed, although this took a while and sometimes by various methods.
On windows 7 this is also the case. Sometimes it connects, seemingly by luck,but mostly not (although it can see the wireless network and is therefore working). I am using a Netgear WPN824v2 router and this is supplying wireless internet to two other computers, both of which run Windows XP.
Basically when I try to connect to my network I receive a message stating that Windows was unable to connect to my network. The wireless card does however see that the network is being broadcast.
Network diagnostics resets the adapter, but this does not resolve the issue. Windows issues an error message stating that there is a problem with the wireless adapter or access point.
To check if the problem is with the adapter or access point I have disabled the adapter and plugged in a wireless USB device (Netgear WPN111), which then works fine. This suggests to me that it is the adapter that is at fault and not the router. I am also using the correct passphrase key to connect.
The Router currently broadcasts a signal using WPA2-psk security and assigns IP and DHCP automatically. I have tried various drivers for the adapter but to no avail. I have also tried to install and use the latest driver from the realtek website (UI and Driver Auto Installation Program (Support Win7))
I also attempted to try an ipconfig but this tells me that the wireless connection media (the Realtek 8185 is disconnected, even though my PC is identifying wireless networks.
Hopefully you can help me resolve this issue. If you require any further information about the system then please don't hesitate to ask.
Regards
Bruce
windows 7 Home premium
AMD Athlon II x4 955 3.2ghz
8bg
ATI Radeon 4890
realtek high def audio
default monitor
1TB
Hello Bruce and welcome to the forum.
Would it be a problem, if for testing purposes, you temporarily turned off wireless encryption on the router to just see if the problem persists. I don't believe I saw that as one of your diagnostic steps in your original post. If we could try this, it might give us something more to go on. Let us know
PartsIsParts
Windows 7 Ultimate 64bit
Intel Pentium D 3Ghz
ASRock G31M-S
4 Gigs PC 6400
Nvidia GeForce 8500 GT
Realtek High Definition Audio Integrated
AOC 19inch X2
1024 X 768 (I'm Old)
Segate ST3160815AS Serial ATAII
Western Digital WD1600AAJA-75PSA0 Serial ATAII
500 watt..don't know mfg.
Giant Black 4u rackmount I've had for years
Stock CPU extra 120s in case
Generic Made in China
Logitech USB Optical Scroll
What ever comcast decides to give me usually 21Mbps up/5mbps
Are you running itunes? Is the Bonjour service running? If so set Bonjour to manual start up and see if that helps.
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
GSkill Phoenix Pro 120GB SSD
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
I'm having roughly the same problem, I can't connect to my neighbour's network, it's unsecured. He is aware of me and happy that I was connecting to it, or well when I was. However since I've upgraded to Windows 7 and XP SP3 on my other machine, I can not connect via my 8185 Extensible 802.11b/g Wireless Device.
Win 7 64 bit
AMD 2
GA-MA770-DS3
4 Gig
Geforce 8800 GTS
Hi People
Thanks for the swift replies. I have been doing some forum searching over the last couple of weeks and have both switched off bonjour and tried to connect without encyption but to no avail. This morning however the internet has started fine, although over the last few weeks this has been very hit and miss with it not working more frequently. I have attached the ipconfig results with it connected. when it wont connect it simply tells me the media is disconnected. I will be restarting the PC several times over the day and will post again if the problem persists.
I have found that some times when it doesnt work'it can be fixed (at least until the next restart) by a variety of methods, but the same one never seems to work twice. Sometimes this can be as simple as leaving the homegroup and going back in or deleting the saved network settings and entering them from scratch. Like i said however, this doesn't always seems to work.
Bruce
8bg
ATI Radeon 4890
default monitor
1TB
ok well the net has gone again. Ive attached a USB adapter for the moment that i usually use with my laptop (although this seems to be causing a BSoD ip conflict if left in too long..Theres always a problem!). I have attached another ipconfig file with the net not working. wireless connection 2 is the one with the problem. The connection does still see wireless networks being broadcast though. Its infuriating! One minute it seems to be fixed and then it goes again!
This time the connection went as i was mucking around trying to give the connection a static ip address. It has since been changed back to automatic.
On a further note the troubleshooter tells me two different problems. Sometimes it tells me there is a problem with the adapter or access point. Other times it tells me that it cannot connect to the hidden network "My Network". Even though the network is not hidden and broadcasts its SSID. It also sometimes tells me that the network key is not valid. I have checked settings and connection 1 is connecting with exactly the same settings..
8bg
ATI Radeon 4890
default monitor
1TB
You could try using wireless N instead of wireless G, it's been known to fix problems with certain adaptors that weren't made for Windows 7.
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
Hi People
Bruce
Bruce old pal, if you are still having problems with your Realtek adaptor.
Maybe just installing the Windows 7 drivers for your Realtek RTL8185L will help. Look halfway down the page, it shows a new driver for Windows 7. Sorry but it took me awhile to find them because I did not have the complete model number for your router.
It's dated 1/11/2010 Hmm sounds like a brand new driver to me. I'd say we have a winner. :sarc:
http://www.realtek.com.tw/downloads/...Downloads=true
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
Digitus / RTL 8185 and no connection
Hi Bruce and chev65.
My son has a brand new PC with Intel i5 processor, Gigabyte motherboard and some big GeForce grafics card. It works smooth and fast. Except if we talk about the wireless internet connection. The net adapter is a Digitus card with an RTL 8185 chip on it. The PC is running Windows 7.
Its behaviour is as random and strange as Bruce describes it. And no chev65, I am sorry to say that the latest Windows 7 driver on Realtek's own website does not help one bit. A good suggestion though but I already tried it.
When the PC starts up it is just fine. I can open up 5 tabpages on an Internet Explorer and run videos from youtube on all 5 whilst reading the news on tabpage 6 and stream live tv on tabpage 7. No problem at all it seems. That just works like that for a while. In fact for such a long while of maybe 15 minutes that I declare "systems are go" to my son and 5 minutes later it sucks. If you click on anything or start up a new browser and key in an url and hit enter it will bring up the first ikons and banners fast enough but that is just the cashing showing itself. The real contents of the page just wont show itself for minutes. It just swirls that blue circle on and on and on. Even if I restart the PC it will not help. Maybe for just 1 minute and then be slooooooow again.
My sons says I have to kill it completely and start up from dead cold. If I do that then yes it works for a handful of minutes and will soon be annoying again. I have uninstalled the drivers and installed them again. I have let Windows 7 find the most suitable driver but also tried out some drivers that I pointed out myself. The name on the netadapter card is Digitus but Windows says it is a Realtek just like Bruce sees. I have tried disable and enable. It just do not want to be stable.
If I grab my Asus laptop and sit in the same room as my sons PC and surf on the internet then there is absolutely no problems on the laptop. My laptop runs Vista. My colleague has the same laptop and he upgraded his Vista to a Windows 7 and he does not have any problems with the wireless either.
The signal strength indicator shows at least 4 out of 5 bars and the Realtek utility tool shows a signal strength of 85% and a quality of that signal to around the same 85%. The IP-address is there and it also says that there is a connection through the router to the internet. Even if I cannot get anything on an internet browser or maybe just a few bits and pieces before it gives up with "page cannot be found" then I can still open up a command prompt and ping different DNS-names for newspapers, the tv-station website, yahoo, youtube and what not. But it will not download an html-page with full contents.
I tried to use Google Chrome and Internet Explorer. When it runs ok for 20 minutes in a row it goes real fast and it seems ok but at any given moment it will give up.
I have looked through the setup on my router to see if there is anything in there, which could be interesting. I turned up some numbers on different stuff and changed the frequence a bit but I did that just out of dispair because as I said: No problems anywhere in the house except my sons new PC.
What is the best course of action? Throw the netadapter card through the window of my dealers shop ( I doubt it is heavy enough for that purpose ) or do any of you guys have some suggestion that I did not think about?
Kind regards,
Henrik Berg Andersen
Intel i5
Gigabyte P55M-UD2
NVidia GeForce 6500
Logitech / mouse combination, wireless
10 mbit
whats the motherboard model number?
Windows 7 Ultimate 32 bit
AMD Athlon 64 X2 4200+ Overclocked to 3.0Ghz
Biostar TF560 A2+
2 Gigs of G.Skill DDR2 800
HIS ATI Radeon HD 2600 Pro With IceQ cooler
6.1 Channel Sound Blaster Live 24 Bit
Dual 20.5 " LG Flatrons W2052TO
1152x864
Dual 36 Gig 10,000 RPM Raptors
430 watt Seasonic 80%+ Dual 12v Rails 2x80mm fans
CHIEFMAX YA-5X
4-80mm case fans 1-140mm case fan freezer 64 Pro CPU cooler
Saitek Eclipse II
A4Tech wireless battery free optical scroll mouse
1.5 meg down 384 up
Logisys LED fan/light controller and dual 16" LED sticks mounted inside top of case all fans are LED all lighting is blue
DVD RW and CD RW both and Memory card reader
Windows 7 32 or 64 bit?
Biostar TF560 A2+
1152x864
CHIEFMAX YA-5X
Saitek Eclipse II
1.5 meg down 384 up
Hi computersplus.
The Gigabyte motherboard is model name GA-P55M-UD2. It also says "Ultra Durable 3" on the box it came in and "Windows 7 support".
Intel i5
Gigabyte P55M-UD2
NVidia GeForce 6500
10 mbit
... and it is Windows 7 in the 64 bit version.
Intel i5
Gigabyte P55M-UD2
NVidia GeForce 6500
10 mbit
ok so your Realtek 8185 802.11b/g Wireless card is not working right with the Netgear WPN824v2 router which is b/g/n
first thing i would do is shut down all PC's unplug power from the modem and the router the plug power back into the modem and wait for lights to become stable then plug power back into the router wait for lights to settle down then restart all PC's one by one and check connectivity you would be surprised what a full reboot of all equipment will do
next i would try either turning off the N radio all together on the router or configure it to run on 2.4 Ghz as apposed to 5 Ghz and make sure to manually set wireless channel on router and card as auto channel select does not always work
post back on results
Biostar TF560 A2+
1152x864
CHIEFMAX YA-5X
Saitek Eclipse II
1.5 meg down 384 up
Hi computerplus.
Well, I have an Zyxel router but never mind that. I will try a total rebout tomorrow (now it is half past 2 at night here) but I did try that before. What I have not tried is the disabling of "the N radio" as you said. I think the router is already running on the 2.4 Ghz frequency range but I will check that too.
Intel i5
Gigabyte P55M-UD2
NVidia GeForce 6500
10 mbit
2.4 Ghz would be standard for the b/g radio but a lot of N routers can do 2.4 or 5 on the N band there have been issues when the N is running at 5 Ghz causing issue with the 2.4 band for some reason
Biostar TF560 A2+
1152x864
CHIEFMAX YA-5X
Saitek Eclipse II
1.5 meg down 384 up
matterhorn sorry about the router make confusion i was reading the original post
Biostar TF560 A2+
1152x864
CHIEFMAX YA-5X
Saitek Eclipse II
1.5 meg down 384 up
what model Zyxel router do you have is it an N band router?
Biostar TF560 A2+
1152x864
CHIEFMAX YA-5X
Saitek Eclipse II
1.5 meg down 384 up
Bruce if you used the setup CD that came with that router on the machine you are having issue with please uninstall all netgear software and just load the driver
Biostar TF560 A2+
1152x864
CHIEFMAX YA-5X
Saitek Eclipse II
1.5 meg down 384 up
I had a mate with a brand new laptop. He had a similar problem in that you could see the network and every now and then it would connect but the connection would not last long. My laptop worked perfectly on with his wireless access point.
Told him to send the laptop back and get a replacement as it was obviously the network card in his laptop due to mine working and his not when they were basically the same. He got the replacement in a week and it worked perfectly since.
Selfbuilt
Intel Core I7 980X
Gigabyte GA-X58A-UD7
8GB 4x2GB Corsair DDR3 2000
NVidia GEForce GTX480 - Gigabyte GV-N480D5
Creative X-Fi
HP LP2475w
1920x1200
2 x 2TB Segate
SilverStone 1500W
CoolMaster HAF 932
Just the Breeze
Standard
Razer Mamba
ADSL
