hi
Every time I wanna use speakers instead headphones,I have to use the same headphones output (green one - back panel), and therefor to disconnect and connect cables.. not very comfortable
I've tried to use the black output, and it worked, but only as a 'rear speakers', both left and right channels worked!
Is it possible to make the rear black output to work as FRONT speakers ?? this way ill be able to have both speakers and headphones available at the same time
In other simple words:Can I use rear speakers as FRONTS ?(when connector to the black rear output)
BTW;I don't wanna use the front panel, only the back panel
Thank you!
Thank you!
win7INTER CORE 2 DUO E4300@3GHZGskill 2gb - 800mhz- 4cl7900gs extreme
- win7
- INTER CORE 2 DUO E4300@3GHZ
- Motherboard
- Gigabyte 965-ds3
- Gskill 2gb - 800mhz- 4cl
- Graphics Card(s)
- 7900gs extreme
- Sound Card
- OB
- Monitor(s) Displays
- 1080P dell
- Screen Resolution
- 1080p
- Hard Drives
- System: Westert Digital WD2500KS 250GB
DATA: Samsung hd103SJ 1TB
- Keyboard
- Logitech wireless + IBM PS2 ( both connected)
- Mouse
- Logitech wireless
- Internet Speed
- 4mbps
- Other Info
- overclocked to 3GHZ
