SB X-Fi Xtreme Audio driver problem with windown 7
Smopot75
7:36 PM
Hey all,
I recently installed windows 7 on my computer and everything worked well accept my sound didn't work.:mad:
I put in my Creative SB X-Fi Xtreme Audio driver CD and tried to install them but I ended up with a BLUE SCREEN! about 70% into the installation
I reaserched that many people have almost the same problem with SB X-Fi xtreme audio drivers and windows 7.
Can any one give me any suggestions of what could be the problem.
Smopot
windows 7 home proIntel(R) Core(TM)2 CPU 6600 @ 2.40GHz2.0 GBGeForce GTS 250
Asus ACPI X86-based PC
windows 7 home pro
Asus P5N-E SLI
2.0 GB
GeForce GTS 250
Daewoo International 17" older than 5 year
320 gigs
500 watt
nonew
none
I'm having a very similar problem!
I have the same card, but mp3's play fine. Even some videos in Youtube play ok. It's all other videos on other websites that aren't playing sound for me.
I get a horrible, barely audible noise, or sometimes a scratchy whiney noise.
It's been doing my head in now for two days... help please!!
Windows 72.8 Duo2 GBnVidia GeForce 7300 GS
Mesh
2.8 Duo
Asus
2 GB
Iiyama 22"
320GB & 1TB (Western Digital)
750 Watt
From posts on the Dell users forum, the SoundBlaster needs Windows 7 drivers. It seems the Vista drivers will not work (and the XP drivers definately will not work). There is a Beta driver on the Creative downloads and many have reported this works in Win 7 and it also corrects a noise problem on some systems with more than 3GB of RAM.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
well i the only problem i have is that the drivers will not get installed every time i do try to install it, IT WONT LET ME! errors and s!@#
windows 7 home pro
Asus P5N-E SLI
2.0 GB
GeForce GTS 250
320 gigs
500 watt
nonew
none
Right... i've finally managed to sort it!! (you've no idea how good this feels!)
The problem was simple in the end. In the "Audio Control Panel" Creative put in with the driver download, there is a setting where you state what type of speaker set up you have... ie 2.1, 3.1, 5.1 etc. It was set to 7.1, so i changed it to 2.1, and bloody bingo!!
Now i've never seen one of these bloody control panels before so didn't even know it was there until just a minute ago.
Mesh
2.8 Duo
Asus
2 GB
Iiyama 22"
750 Watt
The Creative site will see two updates one for the audio consolde launcher while the other is for the driver set. You will likely want the console since that also controls other things like the mixer, EAX effects, equalizer, etc. there.
The software disk that comes along with the card is outdated even for Vista there. It's the same as with many video cards. Which model XtremeAudio are you using there? The PCI or PCIe? For the pci model good for both 32bit and 64bit 7 and Vista 64, Creative Worldwide Support
For the PCIe model good for XP as well as Vista and 7, Creative Worldwide Support
Remember to click the "Show Details" link to the right to read the information on the card you go for there.
    W7 Ultimate x64/W10 Pro x64/W11 Pro Triple Bo...AMD Phenom II X4 975 Deneb 3.6ghz - 965 2nd r...Kingston Hyper X DDR3 1600 1.5v 16gb - Hyper ...MSI HD Radeon 5750 1gb - MSI HD Radeon 6450 o...
    Custom builds = 2
    Asus 1440x900 - HP 1600x900
    Zalman CNPS9900A
    W7 Pro x64/W11 ProAMD Deneb 3.6ghz - 965Kingston Hyper X Fury 8gbMSI HD Radeon 6450 DVI Output
    CUSTOM ASSEMBLY
    W7 Pro x64/W11 Pro
    1600x1080
    NZXT Vulcan mini tower
    DSL 5G
It's all sorted now cheers.
Mesh
2.8 Duo
Asus
2 GB
Iiyama 22"
750 Watt
ok well i played around with windows 7 and dled over 10 different drivers for X-Fi Xtreme Audio
AND FINEALY GOT SOUND TO WORK
ALL IT TOOK WAS 10 WINDOWS UPDATES! w00t!
windows 7 home pro
Asus P5N-E SLI
2.0 GB
GeForce GTS 250
320 gigs
500 watt
nonew
none
Just in time for the New Year! :D
    Custom builds = 2
    Zalman CNPS9900A
    CUSTOM ASSEMBLY
    W7 Pro x64/W11 Pro
    1600x1080
    DSL 5G
Nice one.
Lol.... always check Windows updates first though!
Mesh
2.8 Duo
Asus
2 GB
Iiyama 22"
750 Watt
Once you have things working well there's one thing to know about the optional hardware updates. If you have already gone to the manufacturer for the latest and download the same again off of the update site that can literally trash a working setup.
Typically the updates will see the application side as well as the latest driver set which go hand in hand. The second install of the drivers alone offset that too often where you end up starting all over again. Board chipset drivers unavailable at the board manufacturer on the other hand are generally found with the updates. It kind of works in reverse that way.
    Custom builds = 2
    Zalman CNPS9900A
    CUSTOM ASSEMBLY
    W7 Pro x64/W11 Pro
    1600x1080
    DSL 5G
