Serious, Serious Problems. Help Appreciated!
kylepsp
1:34 AM
Well my windows 7 install was fine all the way up to RTM when my computer started freezing randomly for about a minute. I have tried reinstalling and linking it to a specific application but still cannot find the cause.
I do get an error message in event viewer which says this:
The driver detected a controller error on \Device\Ide\IdePort1.
The times when this error appears do not coincide with when my laptop freezes however. I've tried disabling DMA and formatting my hard disk to no avail.
So if anybody could help me solve this mystery, hopefully without buying a new laptop I'd be very appreciative!
EDIT: I've also tried S.M.A.R.T tests on my hard drive and all came back fine.
Windows 7 RTMIntel Pentium T20802gb DDRMobile Intel 945
DixonsMB
Windows 7 RTM
Intel Pentium T2080
DixonsMB
2gb DDR
Mobile Intel 945
Laptop Display
Hitachi
Hmm that is very odd, does your RTM copy show a build number in the bottom right-hand corner? (just curious)
Also you could try re-burning the DVD (assuming you use a DVD) at the slowest speeds possible. :)
Windows 7 Ultimate, OS X 10.7, Ubuntu 11.04Intel E6750 @ 3.80GHz2x2GB & 2x1GB (6GB) OCZ Reaper 1066MHz @ 1080MHzEVGA nVidia GTX 260 896mb (216 Core) FTW Edition
Custom | Whitebox
Realtek ALC888
21" VIZIO TV
1680x1050 @ 60Hz
Corsair 750W
NZXT Nemesis Elite
Thermaltake SpinQ
Logitech Wireless S520
No it doesn't it is 7600 1685 (im missing a number I can't remember.) I installed it from a hard drive so I dont think the dvd is to blame, I've tried reinstalling many times.
DixonsMB
Windows 7 RTM
Intel Pentium T2080
DixonsMB
2gb DDR
Mobile Intel 945
Laptop Display
Hitachi
Sounds like 7600.16385 .. Where did you obtain the iso from... MSDN/TechConnect or a similar subscription service??
LENOVO K450 @3.0GHZ
64-bit Windows 8.1 Pro
LENOVO
12.00 GB
Intel(R) HD Graphics
Intel HD integtrated
HP 25' ISP Monitor
100mb down/10mb up
I think it was actually a torrent supplied by someone on this site.
DixonsMB
Windows 7 RTM
Intel Pentium T2080
DixonsMB
2gb DDR
Mobile Intel 945
Laptop Display
Hitachi
I also have had this error:
The speed of processor 0 in group 0 is being limited by system firmware. The processor has been in this reduced performance state for 71 seconds since the last report.
DixonsMB
Windows 7 RTM
Intel Pentium T2080
DixonsMB
2gb DDR
Mobile Intel 945
Laptop Display
Hitachi
Could you
1-go into device manager (type device managaer in search) and look for your hard drive. Make sure its listed and isnt "unknown" (have a yellow triangle over it)
2- go into event viewer (yeah type that) and look in the app tab to see if there are any errors listed that relate to the current problem.
If either isnt correct could you use snipping tool (type snipping) to take a screenshot of it and upload it to us
Kne
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
DixonsMB
Windows 7 RTM
Intel Pentium T2080
DixonsMB
2gb DDR
Mobile Intel 945
Laptop Display
Hitachi
The service control error is a timeout. its waiting for a repsonse from dev 0 (hard drive). Is the hard drive internal?, a raid?, sata? something is going on with the HD. that would explain why it carries over from install to install. Btw you can read abt it here Event ID 7009 — Basic Service Operations
Clean install? 32 or 64?
Ken
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
This post was always there?
Damn. I missed that :shock::confused:
Windows 8.1 PRO3rd Generation Intel Core i7‐3612QM CPU @ 2.1...8GB DDR3NVIDIA GeForce GT 525M (128 bit), 1GB Grpahics
DELL VOSTRO 3650
Windows 8.1 PRO
3rd Generation Intel Core i7‐3612QM CPU @ 2.10GHZ
8GB DDR3
1920X1080
750GB 5400RPM
Internal SATA, clean install and 32 bit, I've had the issues with iso's direct from microsoft as well
DixonsMB
Windows 7 RTM
Intel Pentium T2080
DixonsMB
2gb DDR
Mobile Intel 945
Laptop Display
Hitachi
K
On a new clean install, do you get those service errors? Have you upgraded the bios? have you upgraded the 945gm driver?
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
i have noticed since running build 7100 that when i go to access my other two hard drives that it will sit there for about 20 seconds before allowing further access. i thought it was just a problem with the drives. i reinstalled vista and i do not get the problem. i go back into 7 and the problem is back. i do not think 7 is fully supporting the chipset software yet. the reason i say this is the fact that under the beta 7 had a problem with the usb controllers and would drop all usb devises when i would unplug just one. hopefully once the full version comes out mikey-soft will have address this problem.
Windows 7 Eternity Build 7600 RTM Activated x86Core2Duo E84003gis DDR2 6400Asus NVidia 9500 GTX 512mb
InternetLord
Core2Duo E8400
Asus Rampage Formula
3gis DDR2 6400
Sound Blaster X-Fi Xtreme Audio PCI-e
SCEPTRE X22WG-1080P 22"
Western Digital 300gig SATA VelociRaptor 10,000rpm
two 320gig SATA Seagate Barracuda 7,200rpm
700 Watt
U2-UFO Black Powder Coat - Solid Top www.mountainmod.com
7 x 120mm 2,500rpm case fans, Ultra ChillTEC Thermoelectric
Logitech diNovo Edge
Logitech LX8 Laser Mouse
7mbps
Hauppauge WinTV HRV-1800 PCI-e
K
Yes I do, yea driver programs say I'm up to date. However am not sure about how to upgrade my bios, my laptop was store built so I dont really have many settings to fiddle with in the bios, how could I upgrade it?
DixonsMB
Windows 7 RTM
Intel Pentium T2080
DixonsMB
2gb DDR
Mobile Intel 945
Laptop Display
Hitachi
