Solved Shutdown Problem when Power On Virtual Machine
Botard
12:52 PM
Cavite
I don't understand the problem every time I powered on the virtual machine the host was shutdown?
Windows 7 guest, Debian hostAMD FX-6100DDR3/16384 MBytes/2000.6MHzAMD Radeon HD 5500 Series
MSI
AMD FX-6100
880GMS-E41(FX)(MS-7641)
Built-in
Samsung SyncMaster S23B300
ST1000DM003-9YN162 ATA Device
WDC WD5000AAKX-00ERMAQ ATA Device
500W NAXN
APOLLO
XY
Samsung
.79Mbps/1.71Mbps
Google Chrome/FireFox/Internet Explorer
3in1 creative speaker
Please explain more about what is going on and tell us what you are doing.
    Windows 7 pro/Windows 10 ProIntel i7 860 Quad core 2.8 ghz8 gbATI Radeon HD 5770 1 gb ram
    HP Pavillion Elite HPE-250f
    8 gb
    Alienware 25 AW2521HF & Viewsonic
    1920 x1080 & 1680x1050
    WD blue 1 tb & 500 gb.
    FF of course.
    https://www.bestbuy.com/site/hp-pavilion-elite-desktop-intel-core-i7-processor-8gb-memory-1tb-hard-drive/9921493.p?skuId=9921493
    Windows 2012 R2 Data center/Linux Minti3 9100 3.6GHz, 8M cache, 4C/4T8GB 2666MT/s DDR4 ECC UDIMM
    Dell Poweredge T140
    Viewsonic
    1 TB & 750 GB
    https://www.dell.com/en-us/work/shop/productdetailstxn/poweredge-t140?~ck=bt
My pc is good a windows 7 64 bit, no problem when using it alone but powering virtual machine on, the host will shutdown. Totally shutdown the screen went black no power like pulling out the power cord in an outlet accidentally. Oh man, I don't really know what is going on the program. There are times I can use the virtual machine for several minutes while other a few minutes before shutdown.
I tried to look a solution on internet but no specific or a direct answer to my problem. There's no program installed in virtual machine environment. The VMware is a 64bit. One thing in my mind is the host bios, does it need to configure before installing VMware?
Thanks for the attention.
MSI
AMD FX-6100
Built-in
500W NAXN
APOLLO
XY
Samsung
.79Mbps/1.71Mbps
Update, it also shutdown in the host without powering the virtual machine, I have doubt either the physical drive or the power supply.
MSI
AMD FX-6100
Built-in
500W NAXN
APOLLO
XY
Samsung
.79Mbps/1.71Mbps
With a random shutdown your problem is likely either the power supply or the cpu is overheating. It would be different if you are getting blue screens or freezes. Please confirm that you are only getting a shutdown. How have you ruled out the PSU? The next step would be to install speed fan to monitor your cpu temps. SpeedFan - Access temperature sensor in your computer
After you install that install prime95 to stress test your cpu. Watch the temps and turn off prime95 if the temp gets over 60C. GIMPS - Free Prime95 software downloads - PrimeNet
With this happening outside of vmware then your issue isn't with vmware and to answer your question there shouldn't be any bios configurations required for vmware.
    8 gb
    FF of course.
    Dell Poweredge T140
    Viewsonic
    1 TB & 750 GB
Yes only shutdown for now as it also freeze before with some insect noise alike I heard in my drive but this was fixed several times by unplug the cord back and forth in physical drive. Freezes happen when the system unit inside is touched or when I cleaned it.
A while ago I just installed the game in cd drive the first cd was successful but the second one at the middle process was shutdown the host. Then I power on the pc and log on windows password, a few minutes while clicking windows explorer, it happen again. So far, the pc is doing fine and I uninstall the game and deleting manually considering my pc is very sensitive now.
About CPU, is it matter the thermal paste I used because I bought it and didn't know if it work properly or having a brand name not recommended by motherboard manufacturer?
MSI
AMD FX-6100
Built-in
500W NAXN
APOLLO
XY
Samsung
.79Mbps/1.71Mbps
What is wrong with this pc? I installed the speed fan and ran it, then the free prime95. When I opened free prime95 and select stress test the pc shutdown twice same at selecting stress test again.
MSI
AMD FX-6100
Built-in
500W NAXN
APOLLO
XY
Samsung
.79Mbps/1.71Mbps
Your cpu looks like it is burning a little high but not enough to cause a shutdown. Is that while running prime95? What does it get to when prime95 is running? As for thermal compound I used a silver based paste-it is better than the paste that comes with the cpu. I don't know how much you used but you only put a thin layer. You only need to put enough to cover the cpu. Too much and it doesn't work. Also make sure that the heat sink is cleaned out. Every now and then I had to remove the fan off of the heat sink to get all of the dust off. Dust also prevents heat dissipation.
    8 gb
    FF of course.
    Dell Poweredge T140
    Viewsonic
    1 TB & 750 GB
It seems my system cannot handle selecting the stress test in prime95 or any program that might trigger to shut-off the windows.
I took the image above after shut the windows off twice when running prime95. There's no other doing in my system when running prime95 except the system was off randomly. So, I didn't had a chance to snip it like I did the speedfan image.
Ok, for your advice for dust removing, I'll follow it and I'm going to use this speedfan to monitor the temperature whether the heat properly sink, later on after I figure out the issue.
MSI
AMD FX-6100
Built-in
500W NAXN
APOLLO
XY
Samsung
.79Mbps/1.71Mbps
You haven't told me how hot it gets. You can set speedfan to log it's results. That way even if it shuts off you still have a record of what was happening at the time. Please do so and try prime95 again and upload the log. All you need to select to log are the temps. I don't care about anything else. Do you overclock?
    8 gb
    FF of course.
    Dell Poweredge T140
    Viewsonic
    1 TB & 750 GB
NO, I don't want overclocking the cpu.
Here's the pdf file log's result, please let me know if this is what you need.
Again, opening prime95 shut off the windows.
MSI
AMD FX-6100
Built-in
500W NAXN
APOLLO
XY
Samsung
.79Mbps/1.71Mbps
Did you look at that? It only has seconds not temps.
    8 gb
    FF of course.
    Dell Poweredge T140
    Viewsonic
    1 TB & 750 GB
Townsbg, how are you today.
been busy that time the reason I didn't response to you. Until then, I noticed my hard drive not fully working. Now I got a replace from my laptop hard drive spare. So far, I got no issue only the transfer rate is slower than the one hdd I replaced. I still used it as back up saving drive temporarily while looking an almost brand-new drive but the cheapest.
What do you think that noise in the drive is the reason this pc got the issue?
MSI
AMD FX-6100
Built-in
500W NAXN
APOLLO
XY
Samsung
.79Mbps/1.71Mbps
It depends upon the noise. It could simply be that the hard drive was being read from or it could have been a sign of hard drive failure. As for a change in transfer speed, that could happen if you replaced the drive with one of a lower rpm.
    8 gb
    FF of course.
    Dell Poweredge T140
    Viewsonic
    1 TB & 750 GB
Okay, I strongly believe and being hopeful this time my pc is going back to normal. About this hard drive failing, I reformatted it then checked disk to recover bad sectors, and it always found some problems but fixed the windows. So I reattached it to have a second hard drive, to use its life span this one terabytes lame drive.
MSI
AMD FX-6100
Built-in
500W NAXN
APOLLO
XY
Samsung
.79Mbps/1.71Mbps
Windows can't fix bad sectors caused by physical problems with the drive. It can only possibly fix problems with the filesystem.
    8 gb
    FF of course.
    Dell Poweredge T140
    Viewsonic
    1 TB & 750 GB
Have you experience repairing a drive? I really want to try a repair but the book of Mike Meyers' computer skills (2006) wrote not to open the drive and should replace a new one. I have here not seeing the bios but the platter is still rotating.
I was thinking this idea to try when I saw a bunch of defect hard drive posted for sale, 4.5$ each. I don't know other reason why they sell it if hdd is not repairable.
MSI
AMD FX-6100
Built-in
500W NAXN
APOLLO
XY
Samsung
.79Mbps/1.71Mbps
Hard drives are generally only repairable by the manufacturer or experts. It is more cost effective to replace the drive unless it is still under warranty. Depending upon the problem the drive might not be repairable.
    8 gb
    FF of course.
    Dell Poweredge T140
    Viewsonic
    1 TB & 750 GB
For one month observation I found no problem after replacing the hdd, so I think the issue here was solved... Thanks the forum!
MSI
AMD FX-6100
Built-in
500W NAXN
APOLLO
XY
Samsung
.79Mbps/1.71Mbps
