Slow internet speed with wired and wireless connection
DillonH
6:59 AM
Illinois
I recently clean installed windows 7 on an ssd i bought for my custom built computer and after installing all the updates and every driver has even been updated to the latest, I still have slow internet speeds and that's with my ethernet and wirless adapter.
I have google just about everything and can't seem to find how to fix this, but some help would be every appreciated.
Also, I'm not sure which specs and info you need to know for this but just tell me what you need to know and I'll post it in the next reply.
Windows 7 Professional 64bitIntel i5-4690K16.0 GB RamNVIDIA GeForce GTX 970
Intel i5-4690K
ASRock Z97 Extreme6
16.0 GB Ram
500gb SSD 1T HDD
none
I'm using Cable its through NewWave and the package is for 15mg and when I test it with my iphone through the wifi i get around 11mg download with it and at first my pc was getting around 1mg download ive since google things and messed with some stuff and its up to 5mg download and that's using ethernet
Intel i5-4690K
ASRock Z97 Extreme6
16.0 GB Ram
500gb SSD 1T HDD
none
Hi Dillon,
open your network devices >> ethernet & wifi adapter >> Advanced
what are the settings.
Roy
E5300 dual core
medion MS7366
3gb
avixc
n (isp resticted to 72)
mse/pands
palemoon
Can you tell me how to get to network devices? Or are you talking about network adapters in device manager?
Sorry if I'm sounding dumb
Intel i5-4690K
ASRock Z97 Extreme6
16.0 GB Ram
500gb SSD 1T HDD
none
These are the settings on my Intel Ethernet Connection:
Gigabit Master Slave Mode
Interrupt Moderation
Jumbo Packet
Large Send Offload V2 (IPv4)
Large Send Offload V2 (IPv6)
Legacy Switch Compatibility Mode
Log Link State Event
Offloading Options
Performance Options
Priority & VLAN
Receive Side Scaling
Receive Side Scaling Queues
Wait For Link
I also purchased a Gigabyte GC-WB867D-I WiFi adapter and I just unhooked the power cord for it on my motherboard because I thought it might have been the cause for my slow internet speeds.
Here's a screen cap of my Device Manager
Intel i5-4690K
ASRock Z97 Extreme6
16.0 GB Ram
500gb SSD 1T HDD
none
Internet speeds go back to normal when I'm in Safe Mode With Networking
Intel i5-4690K
ASRock Z97 Extreme6
16.0 GB Ram
500gb SSD 1T HDD
none
Still could use some help with this
Intel i5-4690K
ASRock Z97 Extreme6
16.0 GB Ram
500gb SSD 1T HDD
none
Wireless Settings Setup:
Router settings:
Setup; Wireless; Settings; Manual:
802.11 Mode : 802.11 N only
Wireless Channel : 9
Channel Width : Auto 20/40MHz
Encryption: WPA2/AES
Advanced
QoS Engine:
Disable everything - This really slow transfer speeds down!!
Firewall Settings:
Enable SPI: Unchecked
Advanced Wireless:
WLAN Partition: Checked
WMM Enable: Checked
Short GI: Unchecked
Extra Wireless: Unchecked
Save settings reboot router!!!
Wireless Card Settings:
Channel Width 2,4/5Ghz: Auto
AD Hoc power management: Disabled
Ad Hoc QoS mode: WMM Enabled
Fat Channel Intolerant: Enabled
Mixed mode protection: CTS to self enabled
Throughput enhancement: Enabled
windows 7 64 bit1.8 GHz8gb
windows 7 64 bit
1.8 GHz
8gb
1 TB
