Sound Blaster Recon3D PCIe (USB Blue Yeti problem)
Fowyn
10:27 PM
Hi everyone, im new here, i was on the forum creeping, but i have a problem that i am not able to find on how to fix it.
I use a Sound Blaster Recon3D PCIe, i only have my wireless headphones on it.
My microphone i use to broadcast, record, and even use daily to talk to my friends started acting stupid when i installed the (Sound Blaster Recon3D PCIe Drivers).
This is wat it does, whenever i go to my desktop and i go to select record devices (on the bottem right of ur desktop) my blue yeti driver appears and disapears constantly, and after a while it's gone for good untill next pc boot, and all that remains is (Digital-in and Wat-men-hear)
i did contact Creative support team, after 5 days of trying to help me nothing workt, instead i had to reinstall a fresh windows 8 install.
The support team has no idea wat they are doing over there, so i hope some of you guys got a good idea or even an fix! <3
Sorry for my English :)
België
België
Is the microphone also on the wireless headset? Wireless, in most cases, doesn't really use the PC's sound card.
Also, since you have a separate sound card, is your on-board (on the motherboard) audio disabled? If not disable it in the BIOS so it does not conflict with the SoundBlaster.
Also, if you are using the front panel mic jack (if it is not a wireless unit), is the front panel connected to the SoundBlaster instead of the motherboard sound I/O connector?
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
The Blue Yeti is a USB microphone, my headset is a jack (connected in the back)
I did not do the Audio part in the BIOs i don't know how to find it and were to find it.
I don't use front jacks nor USBs, only my Iphone connector by times.
België
België
