sound problems with Realtek ALC 882 sound card
xprojectd24
11:12 AM
I have a HP Media Center PC. the Model number is a1412n I am dual booting xp and windows 7, and in windows 7 I am not getting any sound. When I went to check it out, I realized that the computer was only recognizing the front audio jack. So i plug my speakers into the front jack but it still says nothing is plugged in. It works fine in XP. does anyone have an Idea? I have a Realtek ALC 882 sound card.
Thanks in advance.
Windows XP/Windows 7
    Windows 11 21H2 Current buildAMD Ryzen 9 3950X4 * 32 GB - Corsair Vengeance 3600 MHzEVGA GeForce RTX 3080 Ti XC3 ULTRA GAMING (12...
    The Beast Model A (homebrew)
    AMD Ryzen 9 3950X
    MSI MEG X570 GODLIKE
    Realtek® ALC1220 Codec
    3x 3840 x 2160
    SteelSeries Apex Pro
    Windows Defender + MB 3
    ChromeOS Flex Dev Channel (current)Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz, 250...16 GBIntel(R) HD Graphics 520
    Dell Latitude E5470
    16 GB
    Dell laptop display 15"
    1920 * 1080
    Toshiba 128GB M.2 22300 drive
the link that you directed me to would not let me download the drivers.
I think I downloaded the drivers from another website, but I'm not sure whether I got the XP or Vista version
Vista drivers would be your best bet as windows 7 is more Vista then it is XP
Windows 7 Ultimate Vista Ultimate x64Core 2 Duo E8500 3.16Ghz @ 3.8Ghz2x2Gigs Patriot PC2-6400 LLInno3D GeForce GTX260 216 SP
Home Brew
eVGA 750i FTW
SATA 150GB
SATA II 250GB
USB IDE 750GB Ext.
Liquid Cooling System
Logitech G15 Gaming Keyboard
Logitech G9 Gaming Mouse
check sound options in control panel, that's where I found my problem, working now!
windwos 7 beta920, i5 2400, mobile 5200 c2d9gb, 6gb, 4gbamd 6870, ati 5770, go 7300
hp9130e, xps 8300, acer aspire 563o
windwos 7 beta
9gb, 6gb, 4gb
i had a problem with ALC 882 sound card (integrated with mobo), driver was recognized by w7,but there was no sound, but i managed it with giving manually drivers from ALC880-882_Vista_V6015306.zip found on Internet (vista x64 driver for alc882) and everything works fine now :)
edit: Realtek High Definition Audio Driver R2.14 for Vista works better.
Windows 7 x64
Windows 7 x64
I have an abit I-N37H mobo with realtek integrated sound and i have the same issue where only the front panel is recognized and no sound comes out of it. i have tried the r2.22 drivers that came out recently to no avail. i am going to try what t2n said and manually load the drivers from ALC880-882_Vista_V6015306.zip, but i don't have high hopes.
edit: ALC880-882_Vista_V6015306.zip didn't work, and i created my own thread for my problem seeing as it is slightly different from this threads one: http://www.sevenforums.com/sound-audio/7916-realtek-only-allowing-digital-output.html
Win7 7000 x64Intel Dual core E4600 @2.4ghz4GBevga NVIDIA 8800GT/ NVIDIA 7100 (inergrated)
Win7 7000 x64
ABIT I-N73HD
4GB
Realtek ALC888 7.1 HD integrated
i'm waiting for your report about ALC880-882_Vista_V6015306.zip, abaddon3k (do not forget about checking Realtek High Definition Audio Driver R2.14 for Vista too)
greets, t2n
Windows 7 x64
Windows 7 x64
whoops, that edit wasn't supposed to be r2.22, it was supposed to be the ALC880-882_Vista_V6015306.zip.
the drivers i need would be in the vist64 folder right? (i am on x64)
and i did try 2.14 as well as r1.78, r1.90, r2.16
Win7 7000 x64
ABIT I-N73HD
4GB
could you write some details about your sound card name vendor etc ? i'll try to look for proper driver..
Windows 7 x64
Windows 7 x64
sure thing. the help would be great seeing as i have exhausted all my options.
Its is Realtek ALC888 7.1 HD integrated into an ABIT I-N73HD
Win7 7000 x64
ABIT I-N73HD
4GB
i'll give them a try, thanks a lot!
Win7 7000 x64
ABIT I-N73HD
4GB
I'm using the 2.22 drivers (Vista x64 version) directly downloaded from Realtek's site. Works like a champ. I've read that you should download the .zip version. Just in case you downloaded the .exe version that could be worth a distant try.
Windows 7 Ultimate x64 RC1 (7100), Vista Ulti...Intel Core i7 920Corsair Dominator 6GB DDR3 1600 8-8-8-24 T1Dual EVGA GTX280 SLI
Windows 7 Ultimate x64 RC1 (7100), Vista Ultimate x64 SP1
Intel Core i7 920
EVGA X58 3x SLI
On board Realtek HD Audio
BenQ V2400W 24" LCD Panel
1920x1200
WD Velociraptor 300GB 10k RPM Sata
WD Caviar Black 1TB 7200 RPM Sata
Corsair 750TX
Antec P182 Gun Metal finish
Noctua NH-U12P SE1366
Microsoft Natural Ergo 4000
Logitech LX7 Cordless Optical Mouse
10MB Cable
I have the same computer system as the OP. I've installed the latest Realtek Device drivers for Vista 32/64 bit from the website, and the driver installs fine, and the computer recognizes it, however sound refuses to play from the speakers. When I wear my headphones I can faintly hear the sound, but nowhere near a satisfactory level, and that's at 100% volume on all counts. My sound card is Realtek ALC 882.
I tried it with 64 bit Windows 7, and since that didn't work, I tried 32-bit to see if it would make and difference, which it didn't, so currently, I'm using 32-bit Windows 7.
Any help would be greatly appreciated.
Windows 7 32-bit
Windows 7 32-bit
I have Realtek 880 High Definition Audio on a Asus MotherBoard. My problems look like projectd24 . Do you have an ATI HD graphic card with integrated HDMI , because my windows used the HDMI sound as default and didn't reconized the REALTEK . Afther several hour of search I went into my Bios in the advanced option and I put my integrated audio to ENABLE instead of AUTO and windows automaticly install my REALTEK audio driver and sound work great! :P
windows 7
windows 7
OK, I think my problem is the same. It is NOT solved BUT............
If I plug the headphone into the MIKE input I get a popup that asks what device I plugged in. If I select HEADPHONE, everything works like it did in XP -- except that the headphone is plugged into the mike port.
is yours the same?????????
definitely and issue.
windows 7
windows 7
thanks to aper3 for the recommendation. I was working on an HP media center edition. By changing the audio from auto to enabled, Windows 7 picked up the hardware and installed the appropriate software for the machine. Many thanks.
Regards,
Paul
Paul M. Muhlbach, A+, CNA, MCSE, MCT
Calgary, AB
Windows 7, Linux, MAC OS X , Windows XPCore2Duo T81004 GBIntegrated ATI
Dell Inspiron 1525
Core2Duo T8100
integrated
Integrated ATI
15"
500 Sata 7200 RPM
laptop
built in fan
a follow up on my issue with the headphone jack not working.
I decided it HAD to be a h/w issue so I pulled everything apart determined to find it this time. (I looked once before but didn't find anything).
AH HA!!!!!
The headphone jack switch was not working. After looking all over for a replacement jack and not finding it, I took it apart (the plastic on this one was not glued) and "tweaked" the switch mechanism by bending the moving arm slightly.
Everything is fine now. This procedure is recommended only for those mechanically inclined. I also had to remove the part from the pc board.
windows 7
windows 7
I installed a driver from the realtec site and it works :)
w 7
w 7
