sounds problem after Changing from 32bit to 64 bit
tomo21
2:55 AM
Hi All,
new here so hope i dont piss anyone off by posting in the wrong place etc,:o
Anyway i was using 32bit and decided to go for 64 bit
so on installing Win7(64bit) my little sounds bubble in bottom corner has no gained a little red X next to it and says:
No Audio Output Device Is Installed
i have logitech X-530 speakers that worked fine on 32bit
i also had a realtek software installed on 32bit but dont have a clue which one
thanks
intel
asrock
8gb
you need to get 64-bit drivers
nip over to Realtek's site and look for them
before you install them make sure that you remove any previous drivers
and run something like CCleaner's Registry cleaner to get rid of any "stubs"
benchtec, built to personal specs
i7-965 Extreme Edition (8 Cores) at 3.3GHz (no OC)
BloodRageX58 (Socket1366)
12G Corsair Dominator DDR3 - tripled
2xAMD SapphireNITRO R9 380(4G) crossfire
Sonar(SB)X-Fi onboard
SyncMaster P2050 20"
1600x900 (widescreen)
480G\OCZSolid3SSD, 64G\OCZVertex3SSD,60G\OCZVertex2SSD, 1TB\spinpointF1SATAHDD
1200w Power Station Gold
ANTEC 900/2 all blue lights, etc..
Noctua SE1366 NH-U12P - a tight fit, but a monster cooler!!
Logitech G19 (wired)
Logitech G9 Laser (wired)
150mb unlimited
IE11(RP)
Xbox One, Nokia735 Windows10 mobile, LG HD/DVD/Blu-Ray r/w, CyberlinkPowerDVD15, LogitechZ5500-SS(5.1), LogitechG35Phones-SS(7.1),MSOffice 2007,CorelDrawX7,Painter2016, Wacom Intuos Pro-SE
