Speed issue or lack there of with wireless
dis0wned1
11:01 PM
Australia
Hi I'm currently having a problem with my win7 64 bit desktops wireless speed. It has recently decided to slow to a crawl I'm talking to the point where the speed is measured in bytes not kilobytes when accessing the net and downloading files. I know it's the computer not my network as other wifi gear still works at full speed.
The only change I have made is to switch antivirus from kaspersky to mcafee, I use a Asus wl-138g v2 wifi card( I know it's old but it's been very reliable until now). Any help would be apreciated, thanx in advance.
Windows 7 ultimate 64 bitI7 8608GB DDR3Nvidia Quadro FX1800
I7 860
Gigabyte P55-UD5
8GB DDR3
ASUS 24"
1080p
1TB x3
Antec 750W
Sorry you are having issues dis0wned1!
Disable, or uninstall and burn (with a match) Mcafee.... I had the same issue on a clients lappy! Removed Mcafee and issue went away!
Windows 7 Ultimate 64 bit Steve Ballmer Signa...Intel Core 2 Quad - Q9550 - 2.83GHz stock - O...4GB DDR2 800MHz (PC6400) OCZ ReaperNvidia GE Force 8800 GTS
Homebrew PC - "Alpha_Dawg"
Windows 7 Ultimate 64 bit Steve Ballmer Signature Edition
Intel Core 2 Quad - Q9550 - 2.83GHz stock - OC'd to 3.6GHz
Gigabyte EP45-UD3P
Asus Xonar DX
Samsung SyncMaster 2333HD
WD Caviar Black 750GB - 7200RPM - 32MB cache
WD Caviar Green 1.5TB - 5400RPM - 64MB cache
WD Caviar Green 2.0TB - 5400RPM - 64MB cache
PC Power & Cooling Silencer 750
Gigabyte 3D Aurora
Case is Air - 5ea. 120mm fans (mix of Arctic and Xigmatec)
MS Natural Wireless KB
MS Wireless Mouse
50 mbps down/5 mbps up
AVerMedia - AVerTVHD G2 Dual Tuner Card
A couple of things
Is it still slow if you safe boot (F8) with networking?
Are you using homegroup for networking?
the only real way to test if it is the AV is to un-install just to test. AV apps have hooks into the OS kernal even when disabled.
Ken
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
I run into instances where Norton, Mcafee, and Kerperskys cause latency issues all the time.
Windows 7 64xAMD Turion II Dual-Core Mobile M520 2.30 GHz4GBATI Radeon HD 4200
Toshiba L505
Windows 7 64x
4GB
ATI Radeon HD 4200
I uninstalled mcafee but nothing seems to have changed also windows firewall is returning the following message
"windows firewall can't change some of your settings error code 0x8007042c"
when I try to start it from services.msc I get the following
"windows could not start the service on local computer. Error 1068: the dependency service or group failed to start"
I tracked the dependencies back but they are all running so I gave up at this point and thought I would ask. I don't want to reformat as I have slot of large apps installed I don't want to DL again. To stress how important this is I'm actualy using a mac to talk to you.
I7 860
Gigabyte P55-UD5
8GB DDR3
ASUS 24"
1080p
1TB x3
Antec 750W
I've changed my mind I will reformat it fir the third time this year I just don't seem to have much luck with win 7 this will be my last atempt on windows 7 and if it disentangle work I'll go back to xp atleast it's reliable. Thanks for all your help you guys I'll good rep you all. Now is the fun part of moving everything to backup drives.
I7 860
Gigabyte P55-UD5
8GB DDR3
ASUS 24"
1080p
1TB x3
Antec 750W
Damn McAfee... gets in there and totally hoses the Windows firewall.
Try a repair install 1st.... and dump McAfee! http://www.sevenforums.com/tutorials/3413-repair-install.html
Gigabyte EP45-UD3P
Asus Xonar DX
Gigabyte 3D Aurora
MS Wireless Mouse
