Swapping Out TBS6280 For TBS6982 Or Will They Work Side By Side
Arfer Daley
12:57 PM
U.K
hi folks
I have just obtained a new card as listed I am thinking of Swapping Out TBS6280 For TBS6982 Or Will They Work Side By Side
the TBS6280 DVB T2 dual freeview tuner
the TBS6982 DVB-S2 dual satellite tuner
I am also wondering should I start with a clean copy of Media center or should I just install the new card as well
the 6280 has run flawlessly from when I installed it over a year ago picks up all hd chns that are available I am just wondering which way too jump any thoughts would be greatly received
thanks for readinh the post
Win 7 Pro 64BitCPU Intel Core i7 5820k 3.3GHz 6 CoreG.SKILL Ripjaws 4 (32GB 4 x 8) DDR4 24000MHZ ...MSI GeForce GTX 970 GAMING Twin Frozr V 4GB G...
2016New Self Build 64Bit Win7Pro
Win 7 Pro 64Bit
Asus Intel Rampage V Extreme USB 3.1
G.SKILL Ripjaws 4 (32GB 4 x 8) DDR4 24000MHZ (RED)
MSI GeForce GTX 970 GAMING Twin Frozr V 4GB GDDR5 >
Intel Onboard
Samsung LS27D590CS 27 inch Curve
SSD DRIVE Kingston HYPERX FURY-240G Boot Drive
WD 4 TB Black Performance Desktop Hard Disk Drive (7200 RPM SATA 6
WESTERN DIGI Sata 2Tb Video Storage
WESTERN DIGI Sata 3TB Mp3 Storage
WESTERN DIGI Sata 1TB Backup Image Files
EVGA SuperNova P2 850 W PLATINUM, Fully Modular Power Supp
Thermaltake Level 10 Snow EDition
Noctua NH-D15s (updated for large graph
Logitech S510 inc radio Mouse
Logitech See Above
Upto 100 Meg Yer Right NOT
Norton
IE 11
Logitec Sound System 5100 Knackered Hand Controller
Tv Card TBS 6982Pci-E DVB-S2 Dual Tuner
1x Seagate 1Tb Usb.2.0 External Storage
2x Western 500 Usb.3.0 External Storage
2x Western Digital 3TB External
I will answer my own question yes for you if it helps anyone else yes the two cards are installed and working a treat the only problem I have is media center is a pig too configure the satellite card but I an slowly sorting it finding the correct transponder is the problem for me
Win 7 Pro 64Bit
Intel Onboard
Logitech See Above
Norton
IE 11
