SP1 isn't installed, please do the following:
Installing Windows 7 Service Pack 1
1. Visit the PC manufacturer's website and update
ALL drivers.
DO NOT use Windows Update or the "Update drivers" function of Device Manager.
2. Check Device Manager for any unknown/disabled devices - if there are unknown/disabled devices, fix them with the latest drivers from the device manufacturer's website (not the PC Manufacturer)
3. Visit Windows Update and get all updates
4. Visit Windows Update and get Service Pack 1 (usually under Important Updates). Read these notes for installing SP1:
Steps to follow before you install Windows 7 SP1 and Windows Server 2008 R2 SP1 from the Microsoft Download Center
5. Visit Windows Update and get any other available updates
Only 541 mB of available RAM - please get additional RAM for your system. While waiting for extra RAM, eliminate all unneeded startups and only run one program at a time.
LVUSBS64.sys and CamDrL64.sys both date from 2007 and must be updated. They belong to your Logitech camera and can be obtained from here:
Downloads
Further info on BSOD error messages available at:
http://www.carrona.org/bsodindx.html
The following info is just FYI, I've already addressed the issues that I saw in the above paragraphs:
3RD PARTY DRIVERS PRESENT IN THE DUMP FILES
- Create a System Restore Point prior to doing any of this.
DO NOT mess with the drivers themselves - leave the Windows\System32\drivers directory alone unless we specifically direct you to it!
- Please either update the
older drivers from the device manufacturer's website - or uninstall them from your system.
Reference links are included below.
DO NOT use Windows Update or the Update Drivers function of Device Manager.
- Please feel free to post back about any drivers that you are having difficulty locating.
- Windows Update exceptions may be noted below for Windows drivers.
[FONT=lucida console]
amdxata.sys Tue May 19 13:56:59 2009 (4A12F2EB)
AtiPcie.sys Tue May 05 11:00:22 2009 (4A005486)
Soluto.sys Mon Feb 14 07:25:50 2011 (4D591F4E)
NisDrvWFP.sys Wed Apr 06 16:08:53 2011 (4D9CC855)
cpuz135_x64.sys Wed Sep 21 04:23:41 2011 (4E799F0D)
SASKUTIL64.SYS Tue Jul 12 17:00:01 2011 (4E1CB5D1)
SASDIFSV64.SYS Thu Jul 21 19:03:00 2011 (4E28B024)
MpFilter.sys Wed Apr 06 16:07:29 2011 (4D9CC801)
usbfilter.sys Fri Apr 03 07:39:51 2009 (49D5F587)
Rt64win7.sys Thu Jul 30 07:58:43 2009 (4A718AF3)
GEARAspiWDM.sys Mon May 16 16:56:05 2011 (4DD18F65)
[COLOR=Red]LVUSBS64.sys Sat Feb 03 13:05:16 2007 (45C4CEDC)[/COLOR]
[COLOR=Red]CamDrL64.sys Sat Feb 03 13:17:27 2007 (45C4D1B7)[/COLOR]
atikmdag.sys Tue Jul 21 11:59:53 2009 (4A65E5F9)
RTKVHD64.sys Tue Aug 18 05:29:10 2009 (4A8A7466)
[/FONT]
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
http://www.carrona.org/drivers/driver.php?id=AtiPcie.sys
http://www.carrona.org/drivers/driver.php?id=Soluto.sys
http://www.carrona.org/drivers/driver.php?id=NisDrvWFP.sys
http://www.carrona.org/drivers/driver.php?id=cpuz135_x64.sys
http://www.carrona.org/drivers/driver.php?id=SASKUTIL64.SYS
http://www.carrona.org/drivers/driver.php?id=SASDIFSV64.SYS
http://www.carrona.org/drivers/driver.php?id=MpFilter.sys
http://www.carrona.org/drivers/driver.php?id=usbfilter.sys
http://www.carrona.org/drivers/driver.php?id=Rt64win7.sys
http://www.carrona.org/drivers/driver.php?id=GEARAspiWDM.sys
http://www.carrona.org/drivers/driver.php?id=LVUSBS64.sys
http://www.carrona.org/drivers/driver.php?id=CamDrL64.sys
http://www.carrona.org/drivers/driver.php?id=atikmdag.sys
http://www.carrona.org/drivers/driver.php?id=RTKVHD64.sys
BSOD BUGCHECK SUMMARY
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\021412-18657-01.dmp]
Built by: 7600.16385.amd64fre.win7_rtm.090713-1255
Debug session time: Tue Feb 14 00:37:02.172 2012 (UTC - 5:00)
System Uptime: 0 days 0:34:31.655
Probably caused by : ntkrnlmp.exe ( nt!KiSystemServiceExit+245 )
PROCESS_NAME: NisSrv.exe
BUGCHECK_STR: RAISED_IRQL_FAULT
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
FAILURE_BUCKET_ID: X64_RAISED_IRQL_FAULT_NisSrv.exe_nt!KiSystemServiceExit+245
Bugcheck code 0000004A
Arguments 00000000`773aff2a 00000000`00000002 00000000`00000000 fffff880`05110ca0
BiosVersion = F10
BiosReleaseDate = 08/31/2010
[/FONT]
