usb extension cable or power issues?
charlie3
help?
4:53 AM
Scotland
i have a 15m usb extension cable and i need to run more than one device from it.
At the moment i can only run one thing, a mouse.
I also have a usb hub, from tescos and i was going to use it to connect multiple devices to the one usb cable/port.
I tried doing this but it although the light on the port came on none of the devices plugged in worked or showed and lights or signs at at all?? but the hub works fine when plugged into the computer with no extension.
i tried plugging in a keyboard in individually too, instead of the the mouse and it didn't work, so at the moment i can only run a mouse from that port??
I think it maybe to do with the lack of power from the one port but i am not sure. On the 4 port hub i have it does have a 5v power socket too(to allow more powerful device to run off it) but i don't have a power cable for it.
Will getting the power cable help me?
Anyone else had this problem?
Dell Inspiron 546 & Asus EEE PC 1005HAG & Home Build
Windows 7 Home Premium x64 & Ultimate x64
2.8GHZ & 1.66GHZ & Intel i5-2500k @3.3
Asus p8p67
4GB & 1GB & 4GB
ATI Radeon 3200, Intel intregrated, gtx 570
all intregrated
22" Samsung PP227HD & Dell 20" & sony bravia 32 inch tv
1920*1080, 1024*768, 1980*1080
C: 640gb
External HD: 500gb
netbook: 250
C: 1TB (home build)
Antec tp650
Antec 300
Xilence and Asaka and Thermaltake
Microsoft Ergonomic Desktop 7000, + dell entry, + apple kb.
Microsoft Ergonomic Desktop 7000 & Logitech Trackman Mouse
slow, just slow thats all i can say
15m are you sure? (may be 1.5m)
Is the cable USB 1 or USB 2?
ME/XP/Vista/Win7
the voltage drop on a 15m cable ,running at 5v will be approx 1.1 volt why is it required to be so long ? do you not have an alternative option ?
self build
amd phenom x4 9600
asus m2n32-sli deluxe
corsair twinxs 2x2gb
2x nvidia 1gb 8500gt
onboard
23" PB Viseo 233d
maxtor sata 500gb
maxtor sata 320gb
fujitsu sata200gb
oryxx tornado 750w
thermaltake xaser lll
artic freezer64 pro + 7 case fans
Asus p8p67
4GB & 1GB & 4GB
all intregrated
C: 640gb
External HD: 500gb
netbook: 250
C: 1TB (home build)
Antec tp650
Antec 300
what does this do that my current cable doesn't??
can i try powering the hub or is this my only option
Asus p8p67
4GB & 1GB & 4GB
all intregrated
C: 640gb
External HD: 500gb
netbook: 250
C: 1TB (home build)
Antec tp650
Antec 300
nice find theog :thumbsup:
self build
amd phenom x4 9600
onboard
23" PB Viseo 233d
maxtor sata 500gb
maxtor sata 320gb
fujitsu sata200gb
oryxx tornado 750w
is it powered in some way?
Active USB extension lead - allows a USB connection to be used over the usual 5m limit
that's all i have to go on
Asus p8p67
4GB & 1GB & 4GB
all intregrated
C: 640gb
External HD: 500gb
netbook: 250
C: 1TB (home build)
Antec tp650
Antec 300
my mouse works fine on the 15m cable
Asus p8p67
4GB & 1GB & 4GB
all intregrated
C: 640gb
External HD: 500gb
netbook: 250
C: 1TB (home build)
Antec tp650
Antec 300
charlie3, a mouse only requires about 5ma to run, most usb ports run at 500ma ,the longer the cable length the more ma you loose try powering the hub and see if that helps post back and let us know how you get on :)
self build
amd phenom x4 9600
onboard
23" PB Viseo 233d
maxtor sata 500gb
maxtor sata 320gb
fujitsu sata200gb
oryxx tornado 750w
so this boosts the power without an extra power cable?
im guessing my mouse works as its so low power, yes?
so if i got this i could run a usb hub from the one port and connect a mouse and a keyboard to it?
this would replace one of my existing 5m cables or do i need 3?
is the power cable for the hub still an option?
Asus p8p67
4GB & 1GB & 4GB
all intregrated
C: 640gb
External HD: 500gb
netbook: 250
C: 1TB (home build)
Antec tp650
Antec 300
Asus p8p67
4GB & 1GB & 4GB
all intregrated
C: 640gb
External HD: 500gb
netbook: 250
C: 1TB (home build)
Antec tp650
Antec 300
Active USB Extension Cable?
An Active USB Extension Cable is different to Passive USB Extension Cable in that with active USB extension cable the signal passing through the lead is amplified by the cable's built in repeater. This cable buffers the data passing through it (both upstream and downstream). This buffering ensures signal quality.
How Does It Work?
The 5m Active USB 2.0 Extension Lead can be cascaded so that it can bridge much longer gaps. Alternatively you can add more of the Newlink Active 5m USB 2.0 Extension Leads to give an even longer length. You can daisy chain up to five of these leads giving you up to 25m (depending upon the USB 2.0 device connected).
Anything Else?
The 5m Active USB 2.0 Extension Lead does not need an additional power adapter (current draw is only 5mA). It is 100 percent compatible with USB 2.0 electrical and timing specifications.
ME/XP/Vista/Win7
self build
amd phenom x4 9600
onboard
23" PB Viseo 233d
maxtor sata 500gb
maxtor sata 320gb
fujitsu sata200gb
oryxx tornado 750w
so can i just get 1 and then conect 2 of my existing cables after that? this would still work?
Asus p8p67
4GB & 1GB & 4GB
all intregrated
C: 640gb
External HD: 500gb
netbook: 250
C: 1TB (home build)
Antec tp650
Antec 300
How Does It Work?
Anything Else?
thank you theog thats something ive learned today :thumbsup:
self build
amd phenom x4 9600
onboard
23" PB Viseo 233d
maxtor sata 500gb
maxtor sata 320gb
fujitsu sata200gb
oryxx tornado 750w
well a 5v dc 1a power cable is 14.99 + postage so an active cable will be cheaper, i just want to make sure it will work with 2 other cables.
Asus p8p67
4GB & 1GB & 4GB
all intregrated
C: 640gb
External HD: 500gb
netbook: 250
C: 1TB (home build)
Antec tp650
Antec 300
