USB Flash Drive power issue? (connect/disconnection loop)
BrownChiLD
2:37 AM
Hi Guys
first of all, i want all to know that i am pretty darn good at computers, i build and fix computers for a living, and i research and even make technical reviews myself.. reason i say this now so that my fellow experts here would not bother "spoon feeding" me and stuff.. we can go ahead and talk Geek here..
ALright , w/ that said.. here's my situation..
I'm having abit of a problem w/ my flash drive
connecting it to usb , it powers up, and the OS recognizes the drive w/o a hitch.. default drivers installed and autoplay runs to show me my options..
opening the drive, it shows all my folders and files at the root level.. everything seems normal, and detailed list view reveals size, dates , etc.. all seem normal.
[this is where the problem starts ]
as soon as you do ANYTHING, the darn thing disconnects, and then reconnects..
i tried:
- openning a file
- openning a folder
- renaming a folder (F2 or right click)
- checking properties of any file or folder (either by right click properties, or alt+enter shortcut)
- tried accessing it via DOS mode (inside windows environment)
- tried accessing it using DOS based file explorers from Hiren's boot CD and etc
etc
all i can do is just stare at my files.. so close , yet so far lolz
even if i simply select 1 file (not double click, single click only) as soon as Windows tries to access the file for info-summary on explorer's status bar, it disconnects..
i am able to get properties from the drive though, all seems normal
see: Droplr • Screenshot on 5.30.2012 at 12.20.27 AM.png
FIXES i've tried (and i have tried a lot these are jst some of the main attempts)
- device manager driver manipulation
- tried testing the voltage and mA outputs of my usb ports via software AND hardware testers.. all normal
- tried openning the drive in over 10 computers, different hardware, from windows xp to Ubuntu OS, usb 2 and usb 3 etc..
- tried using my dos based recovery tool, acronis, and other tools, as an attempt to recover data, or atleast make a snapshot image of the drive..
but nothing.. as soon as i do ANYTHING on the drive, it powers off and on.....
i tried leaving the drive folder open (ROOT) where it shows everything.. and just kept it like that for hours, it didnt power off.. but as soon as i did something like go into a folder, powers off and on..
etc etc etc
now, at this point i have diagnosed it to be a flashdrive hardware problem, perhaps in its power management side..
So now im really out of ideas.. so i run here for some help haha..
but given my diagnosis... here's what other advance stuff i wana try on it......but need your feedbacks..
1) OVER-POWERING
- i wanted to try putting more POWER to the flash drive.. 5.2v at 3mA? i think this is a safe increase in power, w/o frying the darn thing.. if so.. HOW DO I DO THIS? do you guys know of a software/board combination that can do this ? set output power to the usb port?
if not, i also thought about using a POWERED usb hub, i even thought of openning the flash drive, and tapping directly into its power pins to add a bit of power and amps to it.. POWER ASSIST... 1.5v battery, some capacitors, etc should do it..
2) TRANSPLANT
- hoping that the actual FLASH MEMORY CHIP is OK and intact, and that the proiblem is w/ the power relay/management of the device, the usb interface or others, i plan to TRANSPLANT this memory chip to another similar or exact working flash drive.. in theory this should work...
these are my last 2 courses of action to attempt data recovery from the drive.. i'd do it but all these requires a lot of work, and i just wanted to hear your thoughts and feedbacks about this before i get my hands dirty...
Regards to all
TJ
Windows 7 x64
AMD A10-4600M
AMD Pumori (Socket FT1)
AMD Radeon HD 7660G
High Definition Audio Device
1600x900@60Hz
Standard PS/2 Keyboard
He says he's already tried accessing it in Linux to no avail. What happens when you access it in Linux or a command-line based utility? Does it disconnect just the same or is there a different type of error?
Have you tried simply imaging the drive via Linux "dd" and then trying to access the files?
XP / Win7 x64 Pro
Intel Quad-Core Q9450 @ 3.2GHz
Asus P5-E
2x2GB GSkill DDR2
NVIDIA GeForce 8600 GTS (EVGA)
Dell 2408WFP
1920x1200
I specifically recommended PuppyLinux and for very sound reasons, including success.
AMD A10-4600M
AMD Radeon HD 7660G
1600x900@60Hz
What does PuppyLinux offer over Ubuntu (or any other) Linux in this situation?
XP / Win7 x64 Pro
Asus P5-E
2x2GB GSkill DDR2
Dell 2408WFP
1920x1200
@All
thanks for your responses
re PuppyLinux, umm yes I would like to know also if it is worth a try, since this runs on Linux base anyway just like ubuntu...
I am not very good at Linux stuffs, but if you think this offers a chance to image the drive, i will.. but does it? considering i already tried DOS BASED imaging tools already. I dont' see how linux based imagers can differ
yes i tried command-line based utilities from DOS w/in Windows, DOS mode alone, and a few other tools from hiren's boot CD collection.. it simply disconnects/powers off as soon as i do anything more than just stare at the root folder..
there are times though using DOS command line, that i can go into a folder and it will show the files and folders within, something i cant do on windows explorer...
Windows 7 x64
I would try imaging the device via Linux. Obviously there is something going on when you attempt to access the files within Explorer. If it can image the device, then you can mount it as a virtual drive in Windows and extract the files that way.
Boot up Ubuntu and insert the USB drive. Open a terminal and type "sudo fdisk -l". It should list all available media devices. Find your USB device in the list, it should be something like /dev/sdb1 or something like that. Once you know that, you can issue the following command:
dd if=/dev/sdb1 of=image.iso conv=noerror,sync
That will create the "image.iso" file of the USB drive in the local directory you're working in. Next, perform the following:
mkdir /mnt/myusb
mount -o loop image.iso /mnt/myusb
cd /mnt/myusb
That creates a directory "myusb" to store your usb files, extracts the iso image (files) to that directory, and takes you there. Now you can check to see what files are available and copy them to whatever device you'd like to in order to save them. If you plug in another USB drive to save them, you can do something like the following:
cp -r /mnt/myusb /media/<USB Drive> (whatever the name of your newly inserted USB drive is)
XP / Win7 x64 Pro
Asus P5-E
2x2GB GSkill DDR2
Dell 2408WFP
1920x1200
Awesome FliGi7, i will surely try that. wil report back
Windows 7 x64
Hi Brownchild - did it work?
I have the same situation (well, not quite as bad, I can copy small files out of my damaged flash, but not big ones, before it blinks). Ray
don't know
wow i forgot to reply sorry, but no it didnt work for my case.. :(
Because when i attempt to image the drive it also gets disconnected.. anything that i do or when it starts to draw more power for some sort of operation, it shuts off or something..
Windows 7 x64
Rats. So what did you do? The only options I see are learn to live without it (that is what has worked fine for about 4 months, but I would still like stuff I put only on that drive), or pay somebody to take the flash apart and move the data part to another flash.
What did work for the smaller files: Instead of trying to copy the whole drive, just copy a folder at a time. (Mine will keep power long enough to do this, yours sounds like it will not.) Then, as it is copying the power gets lost, and the "try again" pop up comes. My pro said best to wait until the second pop up comes, the scan again one, which means power is back. Then click scan only, then quickly click the try again while the getting is good.
This whole thing took about an hour for about 200 files, pretty much had to do all the clicks for each one, but I got them so good enough. But when I tried the same routine for picture files it mostly did not have enough time / power to get them. (This was on a different machine, the first success was on the IT shop's, maybe I will go back there.)
don't know
My last option was just that -- to take it apart and transfer the mem/chip w/ an identical flash drive etc.. but i gave up on it before i could try :(
that's a good idea though w/ that letting the OS wait till the drive comes back online.. well, knowledge for the next time... :)
Windows 7 x64
