Hi, i'm having a few issues currently and have tried googling them but not found any fix. First issue is that my computer is not showing any wireless connections as you can see in the image below, it doesn't display any wireless connections available in my home or in my area. Secondly i'm unable to USB Tether with my phone data to my computer, i've tested with my Laptop and on the laptop, both usb tethering and wireless hotspot connection to the laptop works perfectly fine. However since i can't see any wireless connections on my computer, i can't try to connenct to the hotspot wirelessly so my only choice is to usb tether but that doesn't work either as the little red cross indicates no connection. There's nothing wrong with my phone or any settings since the same settings work fine on my laptop. Also there's a little error icon that shows the message below in the screenshot when i double click it. I need some help on how i can start seeing wireless connections again on my computer and also why usb tethering doesn't work.
Appreciate any help as i've been trying to fix this issue for quite some time now but i've simply gotten no where from google and visiting forums so my only hope is to post in tech help sections on this website, thanks! S8+ phone.
https://i.imgur.com/BWESWxF.jpg
https://i.imgur.com/kVfI1Js.jpg
https://i.imgur.com/HAWn6rY.jpg
- Computer type
- PC/Desktop
