Solved Using Ethernet Cable between devices whilst using WIFI network.
jw416
7:29 AM
Hello,
Without too much information, I'm learning how to use Beckhoff hardware. I have a motor rigged up to a PLC that is programmable via Ethernet using a software called Twincat.
I'm a hardware person so hooking it up was no problem. But I'm venturing out into the world of PLC programming which I'm finding quite new and difficult. I use Google/ YouTube/ internet services to aid me in learning this.
The problem is, to connect with the PLC, my Ethernet port needs to be active. Whilst connected, (whilst programming) I'd like to connect to the internet via WIFI.
I've found a multitude of forums with instructions to change the priority of the network connections using metrics and all that, but none of the solutions allow me to connect to both.
Is it really impossible to connect with a device via Ethernet, whilst connected to the internet using WIFI?
I don't know the exact specs for all the different hardware cards on my laptop, but its a HP ZBook running windows 7.
Much obliged.
Windows 7 professional x64
HP
You may need a crossover cable.
How is everything connected ?
A router ? A switch ?
Skylake Special #666
Intel Core i7 6700K
Asus Sabertooth Z170 Mark 1
EVGA GTX 980 Ti SC x2
Realtek High Definition
AOC G2460PG
Logitech G910 Orion Spectrum
Thanks for your reply.
My laptop is connected to a Wi-Fi router. The PLC is connected directly with an Ethernet cable, from Ethernet port to Ethernet port so to speak.
When I plug in the Ethernet cable the Wi-Fi is disconnected. I know I can stop that happening by changing the interface metric to a lower number than the Ethernet connection, but doing that stops my connection to the PLC whenever Wi-Fi is active. So I effectively have the same problem in reverse.
HP
Is your PLC on a different subnet from the WiFi because if its not you more than likely will have problems.
For example if your Wifi's IP is 192.168.0.X you could set your PLC to 192.168.10.X and after a few min's the computer should remember where it is.
Your best bet would be to grab a cheap router and have that take care of your internet and PLC. Did your ISP supply you with router with more than one lan jack because that would work to, instead of buying another cheap router
Microsoft Windows 7 Ultimate 32-bit 7601Intel(R) Pentium(R) Dual CPU E2160 @ 1.80GHz4.00 GB(1) VNC Mirror Driver (2) Intel(R) G33/G31 Ex...
Compac
MSI Boston
4.00 GB
(1) VNC Mirror Driver (2) Intel(R) G33/G31 Express Chipset
Disabled
Headless
1280 x 960 x 32 bits (4294967296 colors) @ 60 Hz
ST3320820AS ATA Device
Headless
Headless
Malwarebytes pro
Also
Windows 8.1 Laptop and Desktop both Acer
In case you missed what sml156 said because it was at the tail end of his reply, connect your PLC programmer to an ethernet port on your router instead of your PC. That will allow the PC to connect to the router via wifi but be connected to the PLC programmer via the router.
Since you say you prefer hardwire, you could connect both the PC and the PLC programmer to the router via ethernet. If your router has only one ethernet port or you don't have any free ethernet ports, you can use a switch to add more ethernet ports.
Corsair CX 750M
Antec 100
CM 212+
Microsoft Pro IntelliMouse
400M down 8M up
Windows Defender
FireFox
Sorry I should have specified;
The network is at work. I'm calling it the LAN because my company uses a LAN, in that I can login into any computer connected. When logged in I have access to my network drives and so on.
However we do have personal laptops so that I can store files on the laptop, whereby I can only access the files from that laptop. (this is probably all obvious I'm just trying to give you an accurate picture).
The 'LAN' is accessible via either WIFI (routers located throughout the building), or by Ethernet (again, ports located throughout the building).
Most of the time in my job I use large modelling files and transfer massive amounts of data around the network so my preference is to plug in with Ethernet. We have docking stations and everything it's all very good and easy.
But to program the PLC, it has to be connected using an Ethernet cable, and connected with Twincat (the programming software) as if in a network. But I'm totally useless at programming PLC's at the moment and I'm searching for videos and other literature online to help me learn, whilst doing it.
Isn't there a simple setting in windows, in order to listen to both the Ethernet port, and the Wi-Fi 'port'?
Technically I'm networking with the PLC, but it only needs to transfer data. It doesn't need access to the rest of the network, or the internet, or anything. It might as well be a USB connection. (accept it doesn't support a USB connection).
How can I tell what subnet its on? My apologies, I'm at the stage where the saying "A little knowledge is dangerous" definitely applies to me.
HP
Thanks.
Your all giving me great advice I appreciate it. I think If I was at home this would be the perfect solution. I've tried connecting the PLC to the LAN, similarly to your advice, but I'm assuming the firewalls at work stop unknown devices from gaining access because It can't be found.
the PLC doesn't have its own UI, so I'm not even sure how I could go about logging it onto the network.
Thanks again. sorry for the essay posts by the way.
HP
See image attached, hopefully that portrays what I'm trying to achieve more elegantly than I can type it.
HP
I was a bit confused as to why you would use wifi over ethernet, but I think they nailed it.
Intel Core i7 6700K
AOC G2460PG
Do you think its possible to connect with a router like you suggest, but then connect that router to the overall network of the building?
I remember at home a few years back I had a router connected to another router to boost the signal upstairs. (I had a spare router, and a not quite long enough wire to reach upstairs, so I put the other router at the top of the stairs to reach the bedrooms)
Might it be possible to connect one to the main network, effectively creating a sub network with just my laptop and the PLC on it?
Thanks again
HP
Are you doing this at home or at work, If you are doing this at work I highly recommend that you talk to whoever is looking after the network and ask him/her for a solution because hooking up unknown devices at minimum could set off alarms and if you setup your own router that is connected to the company network could cause connectivity and routing issues that will cripple their network.
Yes that will work, But like I said above if this is at work don't don't connect this to the work network
Compac
MSI Boston
4.00 GB
Disabled
Headless
Headless
Headless
Malwarebytes pro
Also
Right,
Ye best not risk it. I will be at work.
Thanks all for your replies, I think I've got enough now to find a solution.
HP
@ sml156 that clip switch in your sig is a good tip for grabbing cmd text.
W10 Pro x64, W7 Pro x64 in VMwarei7 2600K @ 4.4GHz8GB Mushkin @ 1600MHzNvidia GTX 750 Ti
self build
i7 2600K @ 4.4GHz
MSI Z68A-GD80
Nvidia GTX 750 Ti
27" Benq + 27" LG
1080p
500GB 850 Evo SSD + 3 * 2TB Seagate
EVGA 650 GS modular
Antec 300
Seidon 120V v2
62/18 Mbps
Defender (W10) + MSE (W7)
Your Welcome
Your Welcome
And now for my next trick I will press the Tab Key (Only work's in cmd)
:D
Compac
MSI Boston
4.00 GB
Disabled
Headless
Headless
Headless
Malwarebytes pro
Also
