Water Cooling Help!
crimson
Power User
7:00 AM
I'm trying to learn how to setup a simple water cooling heatsink for my i7-2600K.
Does anybody know what items I should get to do this?
Windows 7 Retail
Windows 7 Retail
Windows 7 Pro X64 SP1Intel Core I7-3930k16 GB Gskill DDR3-2133eVGA GTX680
homegrown
Intel Core I7-3930k
Asus P9X79 Pro
eVGA GTX680
Creative X-Fi Titanium
As PA246Q
1920 X 1200
Corsair Force GT, 120 GB
WDC 1.5TB Caviar Black
PCP&C Silencer 750 Crossfire
Silverstone FT02
Noctua NH-D14
cheap Logitech USB
Microsoft Intellimouse Explorer (old optical) USB
6Mb cable
Pioneer BDR-205
Samsung SH-203B
Monsoon 5.1 speakers
Corsair just released the new H80 and H100 hydro
Windows 7 Pro x64 SP1 and Mac OS X 10.8.3Intel Core i7-3820 Sandy Bridge-E at 4.75 GHz8 x Corsair 8GB DDR3 64 GB Kit @1866 Overcloc...GTX 580 and MSI R6870
Asus
ASUS Rampage IV Extreme
8 x Corsair 8GB DDR3 64 GB Kit @1866 Overclocked @2000
HDMI on GPU and ACL898
32" Sony EX-500 120Hz
1920x1080P
1 x Corsair Force Series GT CSSD-F60GBGT-BK (OS)
2 x Western Digital Caviar Black Sata III 750GB (Raid 0)
1 x Western Digital Caviar Black Sata III 1TB (Media)
2 x Western Digital Caviar Black Sata II 640GB (Raid 0)
Corsair Professional Series Gold AX850
Corsair 800D
Corsair H80 High Performance Liquid CPU Cooler
HP Wireless Elite Keyboard
HP Wireless Elite Mouse
Cable, VisionTek Bigfoot Killer 2100 Gaming Network Card
4 x GELID Solutions FN-TX12-15 120mm Case Fan with Superior Temperature Control
1 x Corsair 140mm Case Fan
1 x SilverStone FP55B Aluminum front panel 5.25" to a 3.5" bay converter
1 x Ultra Card Reader
1 x Sony Blu-ray Burner BD-5300S-0B
Thanks for the info. I'm looking at 2 of them, but I can't tell the difference.
H50
Hydro Series
H60
Hydro Series
So if I get this, then it will have everything I need right? I don't need to get any tubes, fasteners, liquid, etc etc...
Windows 7 Retail
Windows 7 Retail
Don't you need a reservoir, pump, radiator, fittings, liquid, etc?
Windows 7 Retail
Windows 7 Retail
They are all in one. Just install it and walk away. By the way you should have someone else help you install the corsair cooler. It can be very hard to install by yourself.
Asus
1920x1080P
Corsair 800D
Why? I don't think any of the parts are that heavy that I need assistance. Are there different sides that need to be held by multiple people?
Windows 7 Retail
Windows 7 Retail
No. You'll likely have to remove the board from the case though (to affix the backplate), but other than that you just mount the block/pump, fasten the radiator/reservoir and you're good to go.
Leak test it and just go on about your business. If you want something a bit more sophisticated but still an all-in-one solution, you can look at XSPC and Swiftech kits.
Windows 10 Technical Preview - x64Core i5-3570K - 4.5GHzG.Skill Sniper 12GB DDR3-1600ASUS GeForce GTX 970 STRIX
ASUS Sabertooth Z77 [B. 2003]
Acer K272HUL
Samsung 840 Evo 250GB (OS), Samsung Spinpoint F3 HD103SJ 1TB (Games), Seagate Expansion 1TB (Additional storage, Backup)
Cooler Master Real Power Pro 750W, Corsair HX1000W
HAF-X
XSPC Rasa RS360
Gigabyte Osmium, Noppoo Choc Mid 87, Corsair K70 RGB
Roccat Kova
50 Mbps up, 50 Mbps down
BitDefender TS 2013, Malwarebytes AM, SUPERAntiSpyware
Razer Vespula Gaming Pad, Razer eXactMat, Blackmagic Intensity Pro, Corsair Vengeance 1500 USB Headset, Google/ASUS Nexus 7
I don't need to remove the board. There's a window behind the Mobo on the case specifically for attaching a back plate for water cooling. I do want something simple, but definitely something more sophisticated than the Corsair thing.
I just need to know what to get before I start. Here is a list of stuff I think I need:
1. The water heatsink that goes on the processor.
2. Radiator.
3. Reservoir.
4. Pump.
5. Tubes.
6. Fasteners.
7. Liquid.
Is there anything I'm missing or will that be everything I need to be good to set it up?
Windows 7 Retail
Windows 7 Retail
I can honestly recommend the XSPC RS or RX360. The difference between the two is the 360mm is thicker in the RX model. If you want something entirely custom I can help there as well, as I'm certain many of us here can.
What case are you using? Oh, and the only thing you're missing are fittings...unless that's grouped with fasteners.
Acer K272HUL
HAF-X
XSPC Rasa RS360
Roccat Kova
At this point we would be more helpful to know the exact case you're using currently.
Windows 7 Ultimate 64
MSI P67A-GD80 b3
XFX Radeon 7870 2GB DDR5
Sound Blaster Z Series Card
1680 X 1050 p
(1) 1 tb WD Black
(2) 1 tb WD green/sata II
(2) 3 tb Seagate Barracuda
(1) 120 gb OCZ Vertex SS
(1) Drobo 5N w/5 Seagate 3tb
CoolerMaster Storm Styker
Basic 120mbps down
Chrome and IE 10
Netgear Nighthawk router
Asus USB 3 & sata 6 PCIe card
Drobo 5N advanced NAS
2. Radiator.
3. Reservoir.
4. Pump.
5. Tubes.
6. Fasteners.
7. Liquid.
nope you got it..I'm using a modded H70 btw and it works quite well...simple to install zero maintenance no leaks etc etc.
If you build a custom loop then try to use compression fittings as much as possible to minimise "chances" of leaks.
Use distilled water also and silver..good quality HS paste like "Arctic Silver" or similar.
good luck with your build...oh and btw leak test the loop BEFORE you mount it up and fire up the PC..won't make you happy to find a leak if your PC is powered on at that time. ;)
Windows 7 Professional 64 bit930 i7 quad O/C 4ghzG Skill 3x2gb O/C to 1603mhz 1T timingEVGA 570
home built
Asus P6X58D premium
EVGA 570
creative titanium
samsung s23a950d..120hz 3D
Western Digital 3X150 Velocoraptors in Raid 5
Antec Quattro 1000 watt
Xigmatek Elysium
Custom Loop..Kryos block.360rad..BP comp fittings etc
Razor arcosa
Razer Diamondback
Wireless so w/e I get at the time
OK thanks. I'll do a little more research. The case I was planning to get is NZXT Gamma.
Windows 7 Retail
Windows 7 Retail
If you choose to do a custom loop (which is way harder, but I recommend it over the all-in-one systems), you will also need to decide on the size of your tubing and make sure it all matches up (I made this mistake) as well as making sure the pump you choose is powerful enough for your system, etc.
~Lordbob
Windows 7 Ultimate x64, Mint 9Intel i5-2500k2x 4Gb Corsair VENGEANCE DDR3-1600NVidia GeForce N260GTX Twin Frozr
Hera
Intel i5-2500k
ASUS P8P67 Pro
Realtek HD OnBoard Audio
ASUS 24" Monitor
Cooler Master Haf 932
Fans
Razer Tarantula
Razer Lachesis
not fast enough
